1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Sequencer problem :iocBuild: Aborting, bad database definition (DBD)!
To: Tasaddaq Khan <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 6 Aug 2015 16:05:20 +0000
It looks like either your dbd file did not include "base.dbd", or your Makefile did not include a line like:
example_LIBS += $(EPICS_BASE_IOC_LIBS)
From: [email protected] [[email protected]] on behalf of Tasaddaq Khan [[email protected]]
Sent: Thursday, August 06, 2015 10:41 AM
To: [email protected]
Subject: Sequencer problem :iocBuild: Aborting, bad database definition (DBD)!
Hi
I have successfully build test1 application using Sequencer but when I run the ./st.cmd command, I face following error:
#!../../bin/linux-x86/test1
## You may have to change test1 to something else
## everywhere it appears in this file
< envPaths
epicsEnvSet("ARCH","linux-x86")
epicsEnvSet("IOC","ioctest1")
epicsEnvSet("TOP","/home/omar/epics/test1")
epicsEnvSet("SNCSEQ","/home/omar/epics/seq-2.2.2")
epicsEnvSet("EPICS_BASE","/home/omar/epics/base")
cd /home/omar/epics/test1
dbLoadDatabase "dbd/test1.dbd"
test1_registerRecordDeviceDriver pdbbase
## Load record instances
#dbLoadTemplate "db/userHost.substitutions"
#dbLoadRecords "db/dbSubExample.db", "user=omarHost"
dbLoadRecords "db/test1.db", "user=omarHost"
Record "vout" is of unknown type "calc"
Error at or before ")" in file "db/test1.db" line 1
Error: syntax error
    at or before "" in file "db/test1.db" line 1
## Set this to see messages from mySub
#var mySubDebug 1
## Run this to trace the stages of iocInit
#traceIocInit
cd /home/omar/epics/test1/iocBoot/ioctest1
iocInit
Starting iocInit
checkDatabase: menuConvert not defined.
## Start any sequence programs
#seq sncExample, "user=omarHost"
seq test1, "user=omarHost"
sevr=info Sequencer release 2.2.2, compiled Mon Jul 20 06:19:58 2015
sevr=info Spawning sequencer program "test1", thread 0x9f46e78: "test1"
epics> sevr=minor test1[0](after 2 sec): assigned=2, connected=0, monitored=1, got monitor=0
My Makefile is
TOP=../..
include $(TOP)/configure/CONFIG
#  ADD MACRO DEFINITIONS AFTER THIS LINE
# Build the IOC support library
LIBRARY_IOC += test1Support
# xxxRecord.h will be created from xxxRecord.dbd
DBDINC += xxxRecord
# Install devXxxSoft.dbd into <top>/dbd
DBD += xxxSupport.dbd
# Compile and add the code to the support library
test1Support_SRCS += xxxRecord.c
test1Support_SRCS += devXxxSoft.c
# Link locally-provided code into the support library,
# rather than directly into the IOC application.
test1Support_SRCS += dbSubExample.c
test1Support_SRCS += test1Hello.c
test1Support_SRCS += initTrace.c
test1Support_LIBS += $(EPICS_BASE_IOC_LIBS)
# Build the IOC application
PROD_IOC = test1
# test1.dbd will be created and installed
DBD += test1.dbd
# test1.dbd will be made up from these files:
test1_DBD += base.dbd
test1_DBD += xxxSupport.dbd
test1_DBD += dbSubExample.dbd
test1_DBD += test1Hello.dbd
test1_DBD += initTrace.dbd
# test1_registerRecordDeviceDriver.cpp derives from test1.dbd
test1_SRCS += test1_registerRecordDeviceDriver.cpp
# Build the main IOC entry point on workstation OSs.
test1_SRCS_DEFAULT += test1Main.cpp
test1_SRCS_vxWorks += -nil-
# Add support from base/src/vxWorks if needed
#test1_OBJS_vxWorks += $(EPICS_BASE_BIN)/vxComLibrary
# Link in the code from the support library
test1_LIBS += test1Support
# NOTE: To build SNL programs, SNCSEQ must be defined
# in the <top>/configure/RELEASE file
ifneq ($(SNCSEQ),)
    # Build sncExample into test1Support
    sncExample_SNCFLAGS += +r
    test1_SNCFLAGS += +r
    test1_DBD += sncExample.dbd
    test1_DBD += test1.dbd
    test1Support_SRCS += sncExample.stt
    test1Support_SRCS += test1.st<http://test1.st>
    test1Support_LIBS += seq pv
    test1_LIBS += seq pv
#   test1_SRCS += test1.st<http://test1.st>
    # Build sncProgram as a standalone program
    PROD_HOST += sncProgram
    sncProgram_SNCFLAGS += +m
    sncProgram_SRCS += sncProgram.st
    sncProgram_LIBS += seq pv
    sncProgram_LIBS += $(EPICS_BASE_HOST_LIBS)
endif
# Finally link to the EPICS Base libraries
test1_LIBS += $(EPICS_BASE_IOC_LIBS)
include $(TOP)/configure/RULES
#  ADD RULES AFTER THIS LINE
____________________________________________________
Please check the Makefile and tell me where is the problem.
Tasaddaq
Sequencer problem :iocBuild: Aborting, bad database definition (DBD)! Tasaddaq Khan
Prev: Sequencer problem :iocBuild: Aborting, bad database definition (DBD)! Tasaddaq Khan
Next: RE: Sequencer problem :iocBuild: Aborting, bad database definition (DBD)! Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
