1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: eclipse error when compile the css source
To: [email protected]
Date: Tue, 25 Aug 2015 19:31:29 +0800 (CST)
Hi kay,
    I have some question about the css source code when I try to compile the css with eclipse. I failed several times, and no one knows about the error, could you please give me a favor?
    I use the CSS  3.2.16, SNS_Sources; linux is Scientific Linux 6; eclipse  Eclipse for RCP and RAP Developers (32)
error (5) :
Description    Resource    Path    Location    Type
PartStack cannot be resolved to a type    OPIRuntimeDelegate.java    /org.csstudio.opibuilder/src/org/csstudio/opibuilder/runmode    line 339    Java Problem
The import org.eclipse.ui.internal.PartStack cannot be resolved    OPIRuntimeDelegate.java    /org.csstudio.opibuilder/src/org/csstudio/opibuilder/runmode    line 58    Java Problem
The method detachView(IViewReference) is undefined for the type WorkbenchPage    RunModeService.java    /org.csstudio.opibuilder/src/org/csstudio/opibuilder/runmode    line 246    Java Problem
The method getPane() is undefined for the type PartSite    OPIRuntimeDelegate.java    /org.csstudio.opibuilder/src/org/csstudio/opibuilder/runmode    line 338    Java Problem
The method getStack() is undefined for the type PartPane    OPIRuntimeDelegate.java    /org.csstudio.opibuilder/src/org/csstudio/opibuilder/runmode    line 339    Java Problem
Thank you very much.
Li,xing
IHEP
Re: eclipse error when compile the css source Kasemir, Kay
Prev: Re: Records for slow control Andrew Johnson
Next: Re: eclipse error when compile the css source Kasemir, Kay
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: AW: Records for slow control Ralph Lange
