I’m wondering why it’s convention that the ai record doesn’t use its convert function when using some types of device support routines. The analog value read function should return status=2 according to the IOC developers guide, and this causes it to not do any LINR type conversion on the VAL field.
I’m wondering why I can’t do this:
record(ai, "$(S):SE:CH1:PVRaw")
field(DESC, "Process Variable CH1")
field(DTYP, "asynFloat64")
field(INP, "@asyn(n1,0,1)")
field(SCAN, "I/O Intr")
field(LINR, “SLOPE”)
field(ESLO, “0.1”)
whatever the device support routine passes to the ai record is what I get in VAL. So to do slope conversions I have to pass it to another ai record using soft channel device support.
Although, I’ve found that using asynInt32 support does return 0 to the record support, causing the conversion to happen to VAL. I believe ai support in streamDevice does the same.
Cheers,
Matt
Spallation Neutron Source
ORNL
- Re: ai record doesn't do convert for floats? nick.rees
- Re: ai record doesn't do convert for floats? Andrew Johnson
Re: "security audit" of EPICS / Channel Access? J. Lewis Muir
<2015>
Re: *****SPAM*****makeBaseApp.pl Error J. Lewis Muir
<2015>
