1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: RE: Unable to build support modules on Windows, with base 3.15.2
To: "'Kevin Peterson'" <[email protected]>, "J. Lewis Muir" <[email protected]>, "Mark S. Engbretson" <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 24 Sep 2015 18:35:38 +0000
> Many of the problems seem to be caused by Makefiles that unconditionally build
> code that doesn't work on Windows, and therefore are a problem for all
> versions of Visual Studio.
I build all of synApps, including the sequencer on Windows, and don't have those problems.  What modules specifically did you have trouble with?
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Kevin Peterson
Sent: Thursday, September 24, 2015 1:33 PM
To: J. Lewis Muir; Mark S. Engbretson; [email protected]
Subject: Re: Unable to build support modules on Windows, with base 3.15.2
On 9/24/15 10:45 AM, J. Lewis Muir wrote:
>> If you succeed at building base, you'll encounter more problems when
>> you try to build other EPICS modules.
> Which problems are these?  If a certain compiler does not build
> EPICS software correctly, it would be good to note that compiler as
> unsupported on Andrew's page.
I have not had a chance to document all of the problems I encountered
trying to build synApps_5_8 with Visual Studio Community 2015.  Many of
The sequencer is one module that is difficult to build on Windows, but
those problems have already been discussed here.
Kevin
Re: Unable to build support modules on Windows, with base 3.15.2 Kevin Peterson
Unable to build support modules on Windows, with base 3.15.2 Heesterman, Peter J
Re: Unable to build support modules on Windows, with base 3.15.2 Jani Hakala
RE: Unable to build support modules on Windows, with base 3.15.2 Mark Rivers
RE: Unable to build support modules on Windows, with base 3.15.2 Heesterman, Peter J
Re: Unable to build support modules on Windows, with base 3.15.2 Bob Soliday
RE: Unable to build support modules on Windows, with base 3.15.2 Mark S. Engbretson
Re: Unable to build support modules on Windows, with base 3.15.2 J. Lewis Muir
Prev: Re: Unable to build support modules on Windows, with base 3.15.2 Kevin Peterson
Next: Re: Unable to build support modules on Windows, with base 3.15.2 Kevin Peterson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
