I’m not convinced that burying windows-specific code like that into the configure command is a good idea.What’s so hard about just noting in the documentation that COM ports above 9 require special naming — and since the IOC shell treats backslashes separately: drvAsynSerialPortConfigure(“L10”, “\\\\.\\COM10”, ……..)
That may depend on which version of asyn you are using. The upcoming R4-27 release contains the following in the release notes:*******************************************Fix to automatically prefix COM port names larger than COM9 (e.g. COM10, COM11, etc.) with "\.\". This is needed for all ports except COM1-COM9. Thanks to Freddie Akeroyd for this fix.*******************************************If you are running the master branch from github you already have this fix. If not then I think you can work around the problem by using the full path name to the port when you open it, i.e. \\.\COM10.
- RE: Serial port COM10: not work? Mark Rivers
- Serial port COM10: not work? Heesterman, Peter J
- Re: Serial port COM10: not work? Jack
sumo - builder of consistent sets of EPICS support modules, now with svn and cvs support Goetz Pfeiffer
RE: Serial port COM10: not work? Heesterman, Peter J
<2015>
2025
<2015>
2025
ANJ, 16 Dec 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
IRMIS
Talk
Documents
Links
Licensing
