1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: EDM display update rate
To: [email protected]
Date: Fri, 23 Oct 2015 16:44:19 -0700 (PDT)
We notice that EDM updates the screen about twice per second.  For
example, using a text control to display a calc record whose VAL
increments 10 times a second shows the count incrementing by five
units every half-second.
It seems this rate was chosen deliberately. My colleague Stefani Banerian
found this message: http://www.aps.anl.gov/epics/tech-talk/2009/msg00415.php
which says "the intention was to check each display about twice per second".
She also found these lines in edmMain/main.cc:
 main.cc:1566:  stat = thread_create_handle( &delayH, NULL );
 main.cc:1775:      thread_delay( delayH, 0.5 );
We would like to increase the update rate to 5/sec or so.  Is any way
to achieve this without changing source code and rebuilding EDM?
(This is for simple displays with text controls showing only seven PVs,
where just one at a time is changing.  These would replace hard-wired
LED displays.)
Jon Jacky
Re: EDM display update rate Sinclair, John William
Prev: EPICS S7plc driver & TIA Portal Nick Levchenko
Next: Re: EDM display update rate Sinclair, John William
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Modbus TCP communication with PLC IDEC FC5A-D12S1E unable to read Internal Relays Mazanec Tomáš
