1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: [External] RE: EPICS BASE-3.14.12.3 32-bit Binaries on 64-bit host Machine
To: "Cusick, Martin-Lee" <[email protected]>, Mark Rivers <[email protected]>, [email protected]
Date: Wed, 09 Dec 2015 16:40:34 -0500
On 12/09/2015 04:27 PM, Cusick, Martin-Lee wrote:
> So I just need some clarity on where you want the EPICS_HOST_ARCH variable set.
The simplest thing to do is not to set it at all.  This used to be a
requirement and the build would fail without it.  With recent Base
releases this variable will be automatically set by Make each time it
runs if it is not set in the process environment.
If you do set it (to do the 32-bit build on 64-bit host trick) then you
should set it as an environment variable in the shell where you run "make".
eg
> $ export EPICS_HOST_ARCH=linux-x86_64
> $ make
Re: [External] RE: EPICS BASE-3.14.12.3 32-bit Binaries on 64-bit host Machine Andrew Johnson
EPICS BASE-3.14.12.3 32-bit Binaries on 64-bit host Machine Cusick, Martin-Lee
RE: EPICS BASE-3.14.12.3 32-bit Binaries on 64-bit host Machine Mark Rivers
RE: [External] RE: EPICS BASE-3.14.12.3 32-bit Binaries on 64-bit host Machine Cusick, Martin-Lee
RE: [External] RE: EPICS BASE-3.14.12.3 32-bit Binaries on 64-bit host Machine Mark Rivers
Prev: RE: [External] RE: EPICS BASE-3.14.12.3 32-bit Binaries on 64-bit host Machine Cusick, Martin-Lee
Next: Re: [External] RE: EPICS BASE-3.14.12.3 32-bit Binaries on 64-bit host Machine Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
