1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: RE: Newbie: How do I view the output of an areaDetector plugin?
To: Phil Atkin <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 14 Dec 2015 17:52:57 +0000
Look at the screen shot for the NDPlugStdArrays plugin here:
http://cars9.uchicago.edu/software/epics/NDPluginStdArrays.html
To view the output of a plugin rather then the output of the detector you change the field labelled "Array port" from SIM1 to ROI1 or OVER1, etc.
That is true for all plugins.  So the OVER1 plugin can get its data directly from the detector (SIM1 in this case) or from another plugin like ROI1 by changing that PV.
From: [email protected] [[email protected]] on behalf of Phil Atkin [[email protected]]
Sent: Monday, December 14, 2015 11:43 AM
To: [email protected]
Subject: Newbie: How do I view the output of an areaDetector plugin?
Imagine for a moment that I know nothing of EPICS, yet have somehow managed to build a working set of software (on Windows) including areaDetector R2-4.  I've even got the ImageJ plugin displaying live images from the simulated detector.
I can configure plugins such as the ROI through the medm interface.  How can I view the output of a plugin, instead of the simulated detector?
Best regards,
Phil
[cid:[email protected]]Pixel Analytics is a limited company registered in England. Company number: 7747526; Registered office: 93A New Road, Haslingfield, Cambridge CB23 1LP
PNG image
Newbie: How do I view the output of an areaDetector plugin? Phil Atkin
Prev: Re: MEDM Extension Make Failed on Ubuntu 15.10 Andrew Johnson
Next: RE: areaDetector: plugin in separate dll Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: Re: Newbie: How do I view the output of an areaDetector plugin? Andrew Johnson
Next: areaDetector: plugin in separate dll Phil Atkin
ANJ, 16 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
