Please send the output of
dbpr Iso:GantryCouch:Collimator:Actual 10
Sent from my iPhone
> On Dec 14, 2015, at 11:22 AM, "[email protected]" <[email protected]> wrote:
> I did the experiment Mark suggested and found that drvModbusAsyn.c is working as
> expected - it returns small negative integers when small negative voltages are applied to the converter. BUT in those cases RVAL is still reported as a large positive integer. Details follow:
>> On Sat, 12 Dec 2015, Mark Rivers wrote:
>> You could add the following printf statement to drvModbusAsyn.c::readPlcInt and see what the output is for that value.
>> case dataTypeInt16:
>> result = (epicsInt16)value;
>> printf("readPlcInt, offset=%d, value=0x%x, result=%d (0x%x)\n", offset, value, result, result);
>> break;
> I did that and got these results. When Vin is a small positive value +0.002 V,
> value is a small positive integer and RVAL is a small positive integer:
> readPlcInt, offset=0, value=0x1, result=1 (0x1)
> dbgf Iso:GantryCouch:Collimator:Actual.RVAL
> DBR_LONG: 6 0x6
> (the voltage varies slightly between the printf and dbgf outputs)
> But when Vin is -0.008 V, value is a small negative integer BUT RVAL is a large positive integer:
> readPlcInt, offset=0, value=0xfff4, result=-12 (0xfffffff4)
> DBR_LONG: 65524 0xfff4
> So it seems RVAL is handled differently than value. Is there some way to make
> RVAL behave like value?
> Jon Jacky
> PS - here are answers to Mark's other questions about MODBUS_DATA and asynReport
>> In your database for the ai record what is the drvInfo field in the INP link? Is it still MODBUS_DATA? If so, that should be fine.
> Yes, dbpr reports the INP field is INP:INST_IO @asynMask(CollimCouch, 0, 16, 1000)MODBUS_DATA
>> Please send the output of the following command:
>> asynReport(1, "CollimCouch")
> I believe addr 0 is connected to Vin in the output shown above.
> epics> asynReport(1, "CollimCouch")
> CollimCouch multiDevice:Yes canBlock:Yes autoConnect:Yes
> enabled:Yes connected:Yes numberConnects 1
> nDevices 6 nQueued 0 blocked:No
> asynManagerLock:No synchronousLock:No
> exceptionActive:No exceptionUsers 0 exceptionNotifys 0
> traceMask:0x1 traceIOMask:0x0 traceInfoMask:0x1
> addr 0 autoConnect Yes enabled Yes connected No exceptionActive No
> exceptionActive No exceptionUsers 0 exceptionNotifys 0
> blocked No
> addr 5 autoConnect Yes enabled Yes connected No exceptionActive No
> blocked No
> addr 3 autoConnect Yes enabled Yes connected No exceptionActive No
> blocked No
> addr 4 autoConnect Yes enabled Yes connected No exceptionActive No
> blocked No
> addr 2 autoConnect Yes enabled Yes connected No exceptionActive No
> blocked No
> addr 1 autoConnect Yes enabled Yes connected No exceptionActive No
> blocked No
> modbus port: CollimCouch
> asynOctet server: AcromagCollimCouch
> modbusSlave: 0
> modbusFunction: 4
> modbusStartAddress: 00
> modbusLength: 011
> plcType: AcromagXT1221
> I/O errors: 0
> Read OK: 2207
> Write OK: 0
> pollDelay: 0.100000
> Time for last I/O 1 msec
> Max. I/O time: 7 msec
> Time per hist. bin: 1 msec
- RE: ai RVAL via asyn + modbus: getting unsigned integer Mark Rivers
- RE: ai RVAL via asyn + modbus: getting unsigned integer jon
<2015>
2025
<2015>
2025
