Ø
i saw field(SCAN, "I/O Intr") in record .. .
Ø
what is mean?
In general SCAN=I/O Intr is used to have records that process automatically when device support gets a callback from the driver. It can be used either for devices that send information asynchronously (without sending a command to ask
for the data), or for drivers that rapidly poll the device and then only process the record when something changes.
You are using the streamDevice support, which has a specific use for SCAN=I/O Intr when you need to read multiple values from a single device response. How to do this is explained here:
http://epics.web.psi.ch/software/streamdevice/doc/tipsandtricks.html#readmany
Ø
i will read data in device status ...
Ø
But device is no reply...like this
Ø
2016/01/04 10:05:10.379
192.100.100.20:4016 write 8
!53ALL\r\n
2016/01/04 10:05:10.414 192.100.100.20:4016 read 15
?531000010100\r\n
2016/01/04 10:05:11.624 MX1_9 BL5C:NOZZLE:GetCryoSolAllSta: No reply from device within 1200 ms
This is from your database and protocol files. You are processing the GetRemoteAllSta and then forward linking to a number of other records.
Ø
record(bi, "$(P)$(D):GetRemoteAllSta")
field(DESC, "Local/Remote All Status")
field(DTYP, "stream")
field(INP, "@devNozzleExchange.proto GetRemoteAllSta $(PORT) $(A)")
field(ZNAM, "Local")
field(ONAM, "Remote")
field(SCAN, ".2 second")
field(FLNK, "$(P)$(D):GetCryoSolAllSta")
record(mbbi, "$(P)$(D):GetCryoSolAllSta")
field(DESC, "Cryo Solenoid All Status")
field(INP, "@devNozzleExchange.proto GetCryoSolAllSta $(PORT) $(A)")
field( ZRVL, "0") field( ZRST, "Off")
field( ONVL, "1") field( ONST, "On")
field( TWVL, "2") field( TWST, "Mid")
field( THVL, "3") field( THST, "Failure")
field(FLNK, "$(P)$(D):GetCryoOnSensorAllSta")
#field(SCAN, "I/O Intr")
### Get All Status of Nozzle Exchanger start ###
GetRemoteAllSta{
out "!53ALL";
in "?53%1d%*9d";
ExtranInput = Ignore;
GetCryoSolAllSta{
in "?53%*1d%1d%*8d";
So the GetRemoteAllSta record and protocol send an !53ALL command and then a number of records need to retrieve their data from the response to that command. The way you have done this is incorrect, because you are telling streamDevice
to read from the device multiple times. That won’t work, you only read from the device once and then parse that single response multiple times.
You need to remove your FLNK fields like the one in GetRemoteAllSta
You need to uncomment lines like this one:
All the records that need to process the response from !53ALL except the GetRemoteAllSta record must have SCAN=I/O Intr, and you don’t want the FLNK fields. This will cause each of these records to process whenever there is any input.
Another way to do this is to use redirection as explained here:
http://epics.web.psi.ch/software/streamdevice/doc/formats.html#redirection
Note that you have several typos in your protocol file, you have ExtranInput = Ignore, but it should be ExtraInput = Ignore (you have an extra “n” character).
On Behalf Of mujin park
Sent: Sunday, January 03, 2016 7:13 PM
To: [email protected]
Subject: I have some question.. in .proto and .db files
what is mean?
2 question
like this
2016/01/04 10:05:09.128
!53ALL\r\n
2016/01/04 10:05:09.163 192.100.100.20:4016 read 15
?531000010100\r\n
2016/01/04 10:05:10.276 MX2_13 BL5C:SCREENS:Measure: No reply from device within 2000 ms
2016/01/04 10:05:10.372 MX1_9 BL5C:NOZZLE:GetCryoSolAllSta: No reply from device within 1200 ms
2016/01/04 10:05:10.379 192.100.100.20:4016 write 8
!53ALL\r\n
?531000010100\r\n
2016/01/04 10:05:11.631 192.100.100.20:4016 write 8
!53ALL\r\n
2016/01/04 10:05:11.666 192.100.100.20:4016 read 15
?531000010100\r\n
2016/01/04 10:05:12.875 MX1_9 BL5C:NOZZLE:GetCryoSolAllSta: No reply from device within 1200 ms
db file...
# Reading
record(mbbi, "$(P)$(D):GetHC1SolAllSta")
field(DESC, "HC1 Solenoid All Status")
field(INP, "@devNozzleExchange.proto GetHC1SolAllSta $(PORT) $(A)")
record(bi, "$(P)$(D):GetShutterSolAllSta")
field(DESC, "Shutter Solenoid All Status")
field(INP, "@devNozzleExchange.proto GetShutterSolAllSta $(PORT) $(A)")
field(ZNAM, "Off")
field(ONAM, "On")
record(mbbi, "$(P)$(D):GetCryoOnSensorAllSta")
field(DESC, "Cryo Cylinder On Sensor All Status")
field(INP, "@devNozzleExchange.proto GetCryoOnSensorAllSta $(PORT) $(A)")
field( TWVL, "2") field( TWST, "On Going")
record(mbbi, "$(P)$(D):GetCryoOffSensorAllSta")
field(DESC, "Cryo Cylinder Off Sensor All Status")
field(INP, "@devNozzleExchange.proto GetCryoOffSensorAllSta $(PORT) $(A)")
field( TWVL, "2") field( TWST, "Off Going")
record(mbbi, "$(P)$(D):GetHC1OnSensorAllSta")
field(DESC, "HC1 Cylinder On Sensor All Status")
field(INP, "@devNozzleExchange.proto GetHC1OnSensorAllSta $(PORT) $(A)")
record(mbbi, "$(P)$(D):GetHC1OffSensorAllSta")
field(DESC, "HC1 Cylinder Off Sensor All Status")
field(INP, "@devNozzleExchange.proto GetHC1OffSensorAllSta $(PORT) $(A)")
record(bi, "$(P)$(D):GetCryoBackAllSta")
field(DESC, "Cryo Back All Status")
field(INP, "@devNozzleExchange.proto GetCryoBackAllSta $(PORT) $(A)")
field(ZNAM, "Back Off")
field(ONAM, "Back On")
record(bi, "$(P)$(D):GetHC1BackAllSta")
field(DESC, "HC1 Back All Status")
field(INP, "@devNozzleExchange.proto GetHC1BackAllSta $(PORT) $(A)")
### Get All Status of Nozzle Exchanger end ###
record(bo,"$(P)$(D):SetCryoNozzleOn")
field(DESC, "Cryo Nozzle ON")
field(FLNK, "$(P)$(D):GetCryoNozzleOn PP")
# field(DTYP, "stream")
# field(OUT, "@devNozzleExchange.proto SetCryoNozzleOn $(PORT) $(A)")
record(bi,"$(P)$(D):GetCryoNozzleOn")
field(INP, "@devNozzleExchange.proto SetCryoNozzleOn $(PORT) $(A)")
record(bo,"$(P)$(D):SetCryoNozzleOff")
field(DESC, "Cryo Nozzle OFF")
field(FLNK, "$(P)$(D):GetCryoNozzleOff PP")
# field(OUT, "@devNozzleExchange.proto SetCryoNozzleOff $(PORT) $(A)")
record(bi,"$(P)$(D):GetCryoNozzleOff")
field(DESC, "Cryo Nozzle Off")
field(INP, "@devNozzleExchange.proto SetCryoNozzleOff $(PORT) $(A)")
record(bo,"$(P)$(D):SetHC1NozzleOn")
field(DESC, "HC1 Nozzle On")
field(FLNK, "$(P)$(D):GetHC1NozzleOn PP")
# field(OUT, "@devNozzleExchange.proto SetHC1NozzleOn $(PORT) $(A)")
record(bi,"$(P)$(D):GetHC1NozzleOn")
field(INP, "@devNozzleExchange.proto SetHC1NozzleOn $(PORT) $(A)")
record(bo,"$(P)$(D):SetHC1NozzleOff")
field(DESC, "HC1 Nozzle Off")
field(FLNK, "$(P)$(D):GetHC1NozzleOff PP")
# field(OUT, "@devNozzleExchange.proto SetHC1NozzleOff $(PORT) $(A)")
record(bi,"$(P)$(D):GetHC1NozzleOff")
field(INP, "@devNozzleExchange.proto SetHC1NozzleOff $(PORT) $(A)")
record(bo,"$(P)$(D):SetNozzleBackOn")
field(DESC, "Nozzle Back On")
field(FLNK, "$(P)$(D):GetNozzleBackOn PP")
# field(OUT, "@devNozzleExchange.proto SetNozzleBackOn $(PORT) $(A)")
record(mbbi,"$(P)$(D):GetNozzleBackOn")
field(INP, "@devNozzleExchange.proto SetNozzleBackOn $(PORT) $(A)")
field( ZRVL, "0") field( ZRST, "Error")
field( ONVL, "1") field( ONST, "Cryo Back Ok")
field( TWVL, "2") field( TWST, "HC1 Back Ok")
record(bo,"$(P)$(D):SetNozzleBackOff")
field(DESC, "Nozzle Back Off")
field(FLNK, "$(P)$(D):GetNozzleBackOff PP")
# field(OUT, "@devNozzleExchange.proto SetNozzleBackOff $(PORT) $(A)")
record(bi,"$(P)$(D):GetNozzleBackOff")
field(INP, "@devNozzleExchange.proto SetNozzleBackOff $(PORT) $(A)")
record(bo,"$(P)$(D):SetCryoNozzleAutoOn")
field(DESC, "Cryo Nozzle Auto On")
field(FLNK, "$(P)$(D):GetCryoNozzleAutoOn PP")
# field(OUT, "@devNozzleExchange.proto SetCryoNozzleAutoOn $(PORT) $(A)")
record(bi,"$(P)$(D):GetCryoNozzleAutoOn")
field(INP, "@devNozzleExchange.proto SetCryoNozzleAutoOn $(PORT) $(A)")
record(bo,"$(P)$(D):SetHC1NozzleAutoOn")
field(DESC, "HC1 Nozzle Auto On")
field(FLNK, "$(P)$(D):GetHC1NozzleAutoOn PP")
# field(OUT, "@devNozzleExchange.proto SetHC1NozzleAutoOn $(PORT) $(A)")
record(bi,"$(P)$(D):GetHC1NozzleAutoOn")
field(INP, "@devNozzleExchange.proto SetHC1NozzleAutoOn $(PORT) $(A)")
record(bo,"$(P)$(D):SetCryoShutterOn")
field(DESC, "Cryo Shutter On")
field(FLNK, "$(P)$(D):GetCryoShutterOn PP")
# field(OUT, "@devNozzleExchange.proto SetCryoShutterOn $(PORT) $(A)")
record(bi,"$(P)$(D):GetCryoShutterOn")
field(INP, "@devNozzleExchange.proto SetCryoShutterOn $(PORT) $(A)")
record(bo,"$(P)$(D):SetCryoShutterOff")
field(DESC, "Cryo Shutter Off")
field(FLNK, "$(P)$(D):GetCryoShutterOff PP")
# field(OUT, "@devNozzleExchange.proto SetCryoShutterOff $(PORT) $(A)")
record(bi,"$(P)$(D):GetCryoShutterOff")
field(INP, "@devNozzleExchange.proto SetCryoShutterOff $(PORT) $(A)")
record(bo,"$(P)$(D):SetSystemReset")
field(DESC, "System Reset")
# field(FLNK, "$(P)$(D):GetSystemReset PP")
field(OUT, "@devNozzleExchange.proto SetSystemReset $(PORT) $(A)")
#record(bi,"$(P)$(D):GetSystemReset")
# field(DESC, "System Reset")
# field(INP, "@devNozzleExchange.proto SetSystemReset $(PORT) $(A)")
record(ao, "$(P)$(D):Mode")
field(DESC, "Control Mode")
field(PREC, "0")
@writetimeout { disconnect; }
@replytimeout { disconnect; }
@readtimeout { disconnect; }
@mismatch { disconnect; }
ReplyTimeout = 1200;
InTerminator = CR LF;
OutTerminator = CR LF;
# Measure current
GetRemoteSta {
out "!50SWS";
in "?50%1d";
ExtraInput = Ignore;
GetCryoSolSta {
out "!51SOL";
in "?51%1d%*2d";
GetHC1SolSta {
in "?51%*1d%1d%*1d";
GetShutterSolSta {
in "?51%*2d%1d";
GetCryoOnSensorSta {
out "!52POS";
in "?52%1d%*5d";
GetCryoOffSensorSta {
in "?52%*1d%1d%*4d";
GetHC1OnSensorSta {
in "?52%*2d%1d%*3d";
GetHC1OffSensorSta {
in "?52%*3d%1d%*2d";
GetCryoBackSta {
in "?52%*4d%1d%*1d";
GetHC1BackSta {
in "?52%*5d%1d";
GetRemoteAllSta{
out "!53ALL";
in "?53%1d%*9d";
GetCryoSolAllSta{
GetHC1SolAllSta{
in "?53%*2d%1d%*7d";
GetShutterSolAllSta{
in "?53%*3d%1d%*6d";
GetCryoOnSensorAllSta {
in "?53%*4d%1d%*5d";
GetCryoOffSensorAllSta {
in "?53%*5d%1d%*4d";
GetHC1OnSensorAllSta {
in "?53%*6d%1d%*3d";
GetHC1OffSensorAllSta {
in "?53%*7d%1d%*2d";
GetCryoBackAllSta {
in "?53%*8d%1d%*1d";
GetHC1BackAllSta {
in "?53%*9d%1d";
GetRobotBackOnSta{
out "!55RBS";
in "?55%1d%*1d";
GetRobotNozzleOffSta{
in "?55%*1d%1d";
SetCryoNozzleOn {
out "!10CON";
in "%1d=%*2c";
@mismatch { in "Error=%1d";}
SetCryoNozzleOff {
out "!11COF";
in "%1d=%*2c";
SetHC1NozzleON {
out "!13HON";
in "%1d=%*2c";
SetHC1NozzleOff {
out "!14HOF";
in "%1d=%*2c";
SetNozzleBackOn {
out "!15BON";
in "%1d=%*2c";
SetNozzleBackOff {
out "!16BOF";
in "%1d=%*2c";
SetCryoNozzleAutoOn {
out "!17ACN";
in "%1d=%*2c";
SetHC1NozzleAutoOn {
out "!18AHN";
in "%1d=%*2c";
SetCryoShutterOn {
out "!19CSO";
in "%1d=%*2c";
SetCryoShutterOff {
out "!20CSF";
in "%1d=%*2c";
SetSystemReset {
out "!21RST";
# in "%1d=%*2c";
# @mismatch { in "Error=%1d";}
