Keeping
with TIMTOWTDI, I was wondering what solutions others would use
to solve a database request.
Problem:
We
have a spark detector that will increment a counter every time a
spark is detected. The user requests an alarm when the counter
increments +5 times within an hour. How can this be implemented
on an IOC?
A
Solution:
I
used came up with a solution using compress records. First, I
created a 3600 element compress record using a circular buffer
that records the value of the PV counter every second for an
hour. Next, I created two more compress records, one that saved
the lowest value, and one that saved the highest value of the
first record (N to 1 Low Value, N to 1 High Value). I then
created a CALC record that calculated the difference of the low
and high values. When CALC is greater than 5 ... then alarm.
Is
there a better implementation to do this? Is there anything
wrong with this solution?
Tim
Alarm for greater than 5 counts in 1 hour
ALG = Circular Buffer
record(compress,"$(S):1HrCmp"){
field(SCAN, "1 second")
field(NSAM, "3600")
field(N, "3600")
field(ALG, "4")
field(INP, "$(S):FltCtr") # ←- Record that increments
ALG = N to 1 Low Value
record(compress,
"$(S):1HrCmpL"){
field(NSAM, "1")
field(N, "3600")
field(ALG, "0")
field(INP, "$(S):1HrCmp CP")
ALG = N to 1 High Value
record(compress,
"$(S):1HrCmpH"){
field(NSAM, "1")
field(N, "3600")
field(ALG, "1")
Difference of High and Low over time of circular buffer
Alarms when count is greater than 5
record(calc,
"$(S):1HrCmp_diff"){
field(INPA, "$(S):1HrCmpL CP")
field(INPB, "$(S):1HrCmpH CP")
field(CALC, "B-A")
field(HIGH, "5")
field(HSV, "MAJOR")
- Re: 5 counts in 1 hour Andrew Johnson
RE: Please, help me. st.cmd Mark Rivers
areaDetector driver pixel types Phil Atkin
<2016>
2025
<2016>
2025
ANJ, 15 Jul 2016 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
IRMIS
Talk
Documents
Links
Licensing
