1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: areaDetector: ADBinX/Y and ADSizeX/Y interactions
Date: Thu, 14 Jan 2016 15:39:37 +0000
As I understand it, the ADSize parameters are intended to determine the dimensions of the _physical_ region of the sensor that is read out.  That's why the constraint imposed is
    ADMin + ADSize <= ADMaxSize
This means that the output array from an areaDetector driver should have dimensions given approximately by ADSize/ADBin for each dimension.
Is this correct?
Phil Atkin
Pixel Analytics is a limited company registered in England. Company number: 7747526; Registered office: 93A New Road, Haslingfield, Cambridge CB23 1LP
RE: areaDetector: ADBinX/Y and ADSizeX/Y interactions Mark Rivers
Prev: RE: Device Support for I2C and GPIO Mark Rivers
Next: Would it be recommended to delete an asynPortDriver object when the IOC exits? Heesterman, Peter J
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: AQUENOS:s7nodave Driver Experience Nick Levchenko
Next: RE: areaDetector: ADBinX/Y and ADSizeX/Y interactions Mark Rivers
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
