1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Dynamically refresh CSS BOY runtime OPI
Date: Fri, 15 Jan 2016 13:53:25 +0000
Hi:
Maybe reconsider your use case.
BOY (EDM, MEDM, ..) work best if you use them as originally intended:
1) Add suitable widget
2) Set PV name
Done.
In BOY, you can use scripts to handle some very special cases, but the portability of scripts cannot be guaranteed through updates of the software and will certainly be slower than using any of the built-in functionality.
If you want a circle that changes color, don’t use a circle with rule or script but instead use the LED widget.
If you want a text that changes content, don’t use a Label w/ rule/script but instead use a TextUpdate widget.
To change displays, use buttons that allow operators to open related displays.
If absolutely have to create a video game:
Use a linking container, and set the “opi_file” property of that one in a script based on your PV.
--> PV will determine what’s displayed inside the linking container.
Like this:
# Script for LinkingContainer that shows either A.opi or B.opi
# pvs[0]: PV like sim://sine that changes positive/negative
from org.csstudio.opibuilder.scriptUtil import PVUtil
if PVUtil.getDouble(pvs[0]) > 0:
   widget.setPropertyValue("opi_file", "A.opi")
else:
   widget.setPropertyValue("opi_file", "B.opi")
-Kay
> Hi all,
> Here is my question:
> I want to refresh BOY runtime OPI dynamically according to a state PV, i.e. if the value of state PV changes, the  OPI can be refreshed once automaticlly(same as click F5). How to use embeded java script to do this?
> Regards,
> Yuliang Zhang
Re: Re: Dynamically refresh CSS BOY runtime OPI Zhang Yuliang
Unable to tunnel CSS CA through ssh tunnels Jon Brinkmann
RE: Dynamically refresh CSS BOY runtime OPI Mazanec Tomáš
RE: Dynamically refresh CSS BOY runtime OPI will.rogers
Prev: Re: Cost effective solution for monitor a large number of temperatures w EPICS Jack
Next: Keithley 7001 Scanner Support Jiro Fujita
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Dynamically refresh CSS BOY runtime OPI will.rogers
Next: Re: Re: Dynamically refresh CSS BOY runtime OPI Zhang Yuliang
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
