1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: alarm handler
To: EPICS Tech-Talk <[email protected]>
Date: Thu, 28 Jan 2016 09:44:39 +0100
Hi Rolf,
There are several different implementations of CA plug-ins for Nagios/Icinga, a common open source tool for monitoring IT infrastructure. Some are so-called "active checks" (run by the Icinga server) doing CA get operations, others are stand-alone servers monitoring CA PVs and feeding the updates into the Icinga server ("passive checks"). The EPICS alarm levels map nicely onto the Nagios/Icinga severities. The Nagios/Icinga ecosystem has a large number of plugins and interfaces offering a wide range of functionality.
For data mining, you can feed the Nagios/Icinga logs into a big data log database, e.g. Splunk, which offers very powerful offline analysis. (Especially if it also gets the logs from IOC consoles, servers and network devices.)
Pointers:
For Nagios/Icinga, Legnaro Labs and BESSY II use the active checks, APS uses a monitoring daemon (passive checks).
Splunk is used at a couple of facilities, including NSLS-II and BESSY II.
I also remember ICALEPCS and EPICS Meeting posters/talks about these things.
Cheers,
~Ralph
On 27/01/2016 17:48, Rolf Keitel wrote:
I would be interested to know if anyone in the non-Control-System-Studio world uses/has an alarm handler other than the motif-based alh.
Thanks - rolf -
alarm handler Rolf Keitel
Prev: RE: alarm handler Lauk Daniel Johannes (PSI)
Next: extensions make error 梁雅翔
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025
Next: Re: alarm handler Pearson, Matthew R.
ANJ, 15 Jul 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
