1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: RE: synApp or hdf5 wrong
To: 梁雅翔 <[email protected]>, tech-talk <[email protected]>
Date: Fri, 29 Jan 2016 14:36:19 +0000
Since the first error is that it cannot find hdf5.h, that is the problem.  You need to edit areaDetector/configure/CONFIG_SITE.local and define the path to your installation of hdf5.  EXAMPLE_CONFIG_SITE.local shows an example of how to do it.
From: [email protected] [[email protected]] on behalf of 梁雅翔 [[email protected]]
Sent: Friday, January 29, 2016 8:18 AM
To: tech-talk
Subject: synApp or hdf5 wrong
Hi, everyone:
   My environment: redhat server 6.0, base3.14.12.5.
   Now I am making SynApps 5.8,there is something wrong.
The message( I have installed the hdf5, make install(success) but make install-check wrong ):
在包含自 ../napi.c:391 的文件中:
../napi5.h:6:18: warning:hdf5.h:no such directory of file
In file included from ../napi.c:391:
../napi5.h:50: Error:expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘attr_info’
../napi5.h:51: Error:expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute_’ before ‘group_info’
../napi5.h:52: Error:expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘nxgroup_info’
../napi.c: 在函数‘determineFileTypeImpl’中:
../napi.c:418: warning:implicit declarative function‘H5Fis_hdf5’
make[5]: *** [napi.o] error 1
make[5]: Leaving directory `/home/lyx/epics3.14.12.5/synApps_5_8/support/areaDetector-R2-0/ADCore-R2-2/ADApp/nexusSrc/O.linux-x86_64'
make[4]: *** [install.linux-x86_64] error 2
make[4]: Leaving directory `/home/lyx/epics3.14.12.5/synApps_5_8/support/areaDetector-R2-0/ADCore-R2-2/ADApp/nexusSrc'
make[3]: *** [nexusSrc.install] error 2
make[3]: Leaving directory `/home/lyx/epics3.14.12.5/synApps_5_8/support/areaDetector-R2-0/ADCore-R2-2/ADApp'
make[2]: *** [ADApp.install] error 2
make[2]: Leaving directory `/home/lyx/epics3.14.12.5/synApps_5_8/support/areaDetector-R2-0/ADCore-R2-2'
make[1]: *** [/home/lyx/epics3.14.12.5/synApps_5_8/support/areaDetector-R2-0/ADCore-R2-2.install] error 2
make[1]: Leaving directory `/home/lyx/epics3.14.12.5/synApps_5_8/support/areaDetector-R2-0'
make: *** [/home/lyx/epics3.14.12.5/synApps_5_8/support/areaDetector-R2-0.install] error 2
I tried to install hdf5 again, still be wrong.
(make install-check wrong  and  make synapp wrong)
Best regards,
Liang
synApp or hdf5 wrong 梁雅翔
Prev: synApp or hdf5 wrong 梁雅翔
Next: Re: BOY Linking Container doesn't support OPI Search Path? Pearson, Matthew R.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025
Next: help with SEQ record Christian Pauly
ANJ, 15 Jul 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
