I vote for the EPICS_RT_MLOCKALL run-time variable. I would like to a have a single build of EPICS base.
SPEC is the application that started this thread. When SPEC is installed it not plre-linked against EPICS base. Rather one points it to the site-version of EPICS base, which is then links against. I don't want to have one version of EPICS base with mlockall() disabled for SPEC and another version with it enabled for my IOCs.
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Andrew Johnson
Sent: Friday, January 29, 2016 2:56 PM
To: [email protected]
Subject: Re: set-user-id root and EPICS 3.15
On 01/28/2016 08:43 AM, Ralph Lange wrote:
> However, this is the second time that we hear of trouble because people
> are running client applications (i.e. CA clients) in real-time context.
> In those cases, the memory locking might not be intended nor useful.
> There is no way for the OS abstraction layer (where the memlock happens)
> to know if the caller is an IOC type or a client type application.
> We already began to reconsider the automatic activation feature.
I think it would be reasonable to require those that want the mlockall()
behaviour to configure it. The main question would be whether this
should be configurable at build-time, or if it can require a run-time
setting. The simplest fix would be something like this:
=== modified file 'src/libCom/osi/os/posix/osdThread.c'
--- src/libCom/osi/os/posix/osdThread.c 2015-03-19 15:22:15 +0000
+++ src/libCom/osi/os/posix/osdThread.c 2016-01-29 20:41:08 +0000
@@ -362,7 +362,8 @@
fprintf(stderr, "LRT: min priority: %d max priority %d\n",
pcommonAttr->minPriority, pcommonAttr->maxPriority);
- if (pcommonAttr->maxPriority > pcommonAttr->minPriority) {
+ if (getenv("EPICS_RT_MLOCKALL") &&
+ pcommonAttr->maxPriority > pcommonAttr->minPriority) {
status = mlockall(MCL_CURRENT | MCL_FUTURE);
if(status) {
fprintf(stderr, "Unable to lock the virtual address space
using mlockall\n");
That would require IOCs that need the memory locking to have set the
EPICS_RT_MLOCKALL environment variable before they are executed. A
slightly more complicated solution would allow locking to be turned on
at build-time in the configure/CONFIG_SITE_ENV file, but it could be
turned off again at run-time with an environment variable.
If you currently rely on the current mlockall() behaviour of Base and
wish to influence our decision, please speak up before we commit any
changes.
- Andrew
There are only two hard problems in distributed systems:
2. Exactly-once delivery
1. Guaranteed order of messages
-- Mathias Verraes
- RE: set-user-id root and EPICS 3.15 Jemian, Pete R.
- set-user-id root and EPICS 3.15 Gerry Swislow
- RE: set-user-id root and EPICS 3.15 Mark Rivers
- Re: set-user-id root and EPICS 3.15 Ralph Lange
- Re: set-user-id root and EPICS 3.15 Andrew Johnson
<2016>
<2016>
