1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Show areaDetector image with BOY IntensityGraph
To: Mark Rivers <[email protected]>, "Pearson, Matthew R." <[email protected]>
Cc: "[email protected] list" <[email protected]>
Date: Wed, 3 Feb 2016 15:51:04 +0000
It seems to have a separate setting, in Preferences... CSS Core... EPICS.
Since the ImageJ plugin displays OK, my IOC also has a large-enough setting.
Phil
On 03/02/2016 15:48, Mark Rivers wrote:
Does CSS-BOY use the EPICS environment variable EPICS_CA_MAX_ARRAY_BYTES, or do you have to set this in a Java properties file?  I changed ImageJ (which is also Java) so it uses the environment variable, but I don’t know what BOY does.
From: [email protected] [mailto:[email protected]] On Behalf Of Phil Atkin
Sent: Wednesday, February 03, 2016 9:36 AM
To: Pearson, Matthew R.
Cc: [email protected] list
Tomas, Matthew,
Thanks for your replies, but I'm still stuck.
CSS-BOY is displaying my camera control screens correctly, and my camera reacts accordingly.  It's delivering images, because I can see them in the ImageJ display or through caget; I just can't see them on the Intensity Graph widget.  Not with my own screen and not with Tomas', either.  Tomas' screen does show a couple of the camera properties that are compatible with my camera - but the Intensity Graph widgets just show 'No data'.
I've been through all the properties of my Intensity Graph widget and compared them against Tomas' example; they are simpler now (I removed the scripts and rules, which I think did come from an example; this at least prevents the repetitive error messages).
I've been through the PV names and macros, and nothing seems amiss.
The camera is displaying monochrome, 16-bit images.  So Maximum/Minimum are set to 65535/0.  RGB Mode is false.
max_array_bytes is 16000000, which should be plenty for a 500x500x16bit image.
How do I check the version of the widget I'm using?  What version do you have?  (I know; I'm clutching at straws).
Cheers,
Phil
On 03/02/2016 15:15, Pearson, Matthew R. wrote:
Hi Phil,
For the IntensityGraph, I set these properties:
PV Name - the waveform PV name
Data Width
Data Height
X Axis Max and Min
Y Axis Max and Min
For my generic screens I actually have embedded rules in the widget that set the sizes up. They read the required values from the areaDetector stdArray plugin, which produces the waveform. That way I only have to bother with the PV name.
The error that you mention seems to indicate that you have an embedded script in the widget, copied from an example, which I suspect that you can remove?
In the running OPI you can also right click and select “Show Macros” which might help you figure out any PV name issues. Also, hover over the graph widget and see what the tooltip says.
Also make sure that the max_array_bytes property is set suitably large (in CSS Preferences -> CSS Core -> EPICS).
Can you see any PVs at all in CSS? Try setting up a simple text monitor on one of the scalar PV values in the stdArrays plugin. If not, then check the other settings in CSS Preferences -> CSS Core -> EPICS.
Cheers,
Matt
Data Acquisition and Control Engineer
Spallation Neutron Source
Oak Ridge National Lab
On Feb 3, 2016, at 6:36 AM, Phil Atkin <[email protected]> wrote:
Can anyone get me started with this?  I'm inexperienced with everything: EPICS, areaDetector, CSS, BOY, Java ... you name it.
My IOC is working and I can display images using the ImageJ plugin.  My "PCPrefix" in that case is "13SIM1:image1:"
I've followed this post: https://groups.google.com/forum/#!topic/css-boy/-gUYqgHHUag - but no luck.
Having placed my Intensity Graph widget, how should I set the PV Name property?  What else needs to be set?
What I'm seeing in the log is the following:
2016-01-27 18:36:32 ERROR: Error in ../../BOY Examples/scripts/SetIntensityGraphData.js on IntensityGraph.
org.mozilla._javascript_.WrappedException: Wrapped java.lang.NullPointerException: PV loc://dataSource has no value. (script#5)
Phil
<Logo small.png>Pixel Analytics is a limited company registered in England. Company number: 7747526; Registered office: 93A New Road, Haslingfield, Cambridge CB23 1LP
Show areaDetector image with BOY IntensityGraph Phil Atkin
Re: Show areaDetector image with BOY IntensityGraph Pearson, Matthew R.
Re: Show areaDetector image with BOY IntensityGraph Phil Atkin
RE: Show areaDetector image with BOY IntensityGraph Mark Rivers
Prev: RE: Show areaDetector image with BOY IntensityGraph Mark Rivers
Next: Removing this email from subscription. Steven
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Show areaDetector image with BOY IntensityGraph Hartman, Steven M.
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
