1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: Guide needed in order to work with the EPICS related Git repositories
To: <[email protected]>, <[email protected]>, <[email protected]>
Cc: [email protected]
Date: Tue, 16 Feb 2016 20:41:56 -0800
Hi Ulrik and Mark,
I was comparing my procedure for submitting patches to areaDetector to
the areaDetector-Git-Workflows wiki page and noticed that the wiki doesn't
recommend feature branches for contributors.    I found w/ my areaDetector
contributions that it was best not to make any commits directly on my forked
master branch.
While it probably works out ok if there's a simple change that gets accepted
right away, problems happen if the change isn't accepted right away, or if you
have multiple pull requests and some need more work or aren't accepted.
Here's the procedure I've been using.
# To submit a patch as a new pull request
1. Make sure your master branch is uptodate
git pull origin master
2. Switch workspace to master prior to creating each new feature staging branch!
git checkout master
3. Create feature staging branch
git checkout -b feature-name
4. Apply patch (or make changes to files directly)
patch --strip 0 -i path_to_patch_file
5. Use git diff and git status to make sure all is well
5a. Be sure to expand all tabs in any changed lines
6. Commit changes to local git repo
git commit -a -m "What this patch does"
7. Push back to orgin on github
git push -u origin feature-name
8. Go to github and submit pull request(s) to developer's fork
This has the advantage of keeping each proposed change on it's own branch
where it can be tweaked or discarded as needed w/o impacting the master branch.
What do you guys think?
Should this be added to the wiki?
- Bruce
On 02/16/2016 03:26 AM, [email protected] wrote:
Hi Han,
In order to contact the developers (at least for areaDetector - but probably also for other modules) it is useful to simply create an issue-ticket on the github repository. For areaDetector this is often where contributors start by presenting a new idea or change that they would like to see and a discussion is had about how to best implement the new feature. If you start the description by volunteering to work on it then maintainers are usually happy to guide you in the right direction :-)
See for example a recent ticket on areaDetector/ADCore where we had an extensive debate about a requested change: https://github.com/areaDetector/ADCore/issues/145 . I expect it is likely to be followed up with a Pull Request later on - at which point we will review and discuss the implementation details.
Cheers,
Ulrik
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Jeong Han Lee
Sent: 15 February 2016 22:31
To: Mark Rivers; [email protected]
Cc: Jeong Han Lee
Hi Mark,
   Thank you for your workflow. It is the exactly what I am looking for!
   And I should follow your comment in order to work with EPICS projects. Actually, I did them in one EPICS project without telling anyone what I would like to do, then I thought, I forgot to discuss this early with main developers and maintainers after I saw Ralph's comment.
   Thank you again, I will understand your workflow first, then, I should do it them again with the proper procedure.
   Han
On 02/15/2016 10:27 PM, Mark Rivers wrote:
Hi Han,
I'm not sure exactly what you would like.  For the EPICS areaDetector
project there is a Github workflow guide here:
https://github.com/areaDetector/areaDetector/wiki/areaDetector-Git-Workflows
 It is probably always a good idea to talk to the main developers
early.  If you are doing a small patch then cloning and doing a pull
request back to the master branch is a typical workflow.  But if you
are doing some major change then the developer will probably want to
create a branch for you and other developers to work on, and then you
do pull requests back to that branch.
-----Original Message----- From: [email protected]
Sent: Monday, February 15, 2016 2:47 PM To: [email protected]
Subject: Guide needed in order to work with the EPICS related Git
repositories
I would like to have a *nice* guide, which is always I could get in
here, in order to work with the EPICS related Git repositories at
github.com.
Is there any procedure which I should follow in order to do any pull
requests? Should it be better to talk plan to main developers or
maintainers before forking, doing pull requests, or both?
It looks like to add more features in some existent projects in near
future, but I don't have clear idea how to do this. Please guide me
to minimize any difficulties.
Thanks, Han
Bruce Hill
Member Technical Staff
SLAC National Accelerator Lab
2575 Sand Hill Road M/S 10
Menlo Park, CA  94025
RE: Guide needed in order to work with the EPICS related Git repositories ulrik.pedersen
Guide needed in order to work with the EPICS related Git repositories Jeong Han Lee
RE: Guide needed in order to work with the EPICS related Git repositories Mark Rivers
Re: Guide needed in order to work with the EPICS related Git repositories Jeong Han Lee
Prev: Re: Problem compiling epicsOnce.cpp Eric Norum
Next: RE: Guide needed in order to work with the EPICS related Git repositories ulrik.pedersen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: RE: Guide needed in order to work with the EPICS related Git repositories ulrik.pedersen
ANJ, 15 Jul 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
