1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Cost effective solution for monitor a large number of temperatures w EPICS
To: <[email protected]>, <[email protected]>
Date: Wed, 17 Feb 2016 12:25:37 +0000
I came across this:
http://tmi.yokogawa.com/us/products/oscilloscopes/scopecorders/dl850edl850ev-scopecorder/
No idea about EPICs drives, but seems to match your signal density.
Austen Rose
(x8495)
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Jack
Sent: 15 January 2016 13:45
To: [email protected]
Subject: Re: Cost effective solution for monitor a large number of temperatures w EPICS
Hi all,
I want to express my deep appreciation for the helps and suggestions you have offered me on this topic.
-Mauro
On 1/14/2016 10:47 AM, Mazanec Tomáš wrote:
> Hi Mauro
> If you seek more distributed and perhaps effortless solution, MOXA ioLogik E1260 is 6x RTD , incl. PT100, box which talks MODBUS/TCP. (http://www.moxa.com/product/ioLogik_E1260.htm ).
> We have an EPICS IOC to read the sensors. Feel free to ask for sources. So far, we use it as a bench-top device. Additionally, temperatures are published on E1260 internal web-server.
> For, lets say, more serious stuff, guys next door developed a PCB with Temp&Humi sensor which is then read by an industrial analog input 0--10Volts (NI C-RIO in our case).
> Tomas
> Od: [email protected] [[email protected]] za uživatele [email protected] [[email protected]]
> Odesláno: 13. ledna 2016 12:46
> Komu: [email protected]; [email protected]
> Předmět: RE: Cost effective solution for monitor a large number of      temperatures w EPICS
> Hi Mauro,
> 100 sensors is quite a large number to handle. One of your problems might be cabling density. Are all the signals coming from one relatively contained area, or are they widely distributed? Could you consider distributed I/O and divide the problem in that way? Are you planning 2, 3 or 4 wire measurement connections - how long will your cabling be? You did not comment on required instrumentation accuracy. As you comment, cost and reliability questions also come into the decision making process. Would multiplexed readings be appropriate, rather than 100 direct connections to the instrumentation?
> Anyway some ideas:
> VME crate, carrier cards, ADC IP modules and PT100 PIMS. I am guessing that there are quite a few ADC/PIM combinations used by other facilities. We use Hytec Electronics modules for this, but never at the density you suggest. Depending on components used, you should be able to find EPICS support.
> Beckhoff solutions - but I am not familiar with their range for this type of application and number of signals.
> Agilent meters offer some multiplexed solutions, but again, not at this signal density.
> Finally, you might consider using a PLC to marshal your inputs. We use Omron PLCs and they have 6 channel modules, but at 100 signals this might be difficult.
> If you could distribute the I/O then all the above have merits.
> I look forward to hearing how you solved this.
> Regards,
> Austen Rose
> (x8495)
> I'm looking to find something that works out of the box. The PT100 is a requirements.
> Beckhoff has a KL320X, I thought someone has experienced on that...
> I've to balance the cost and the reliability of this solution.
> Thansk,
> -Mauro
> This e-mail and any attachments may contain confidential, copyright and or privileged material, and are for the use of the intended addressee only. If you are not the intended addressee or an authorised recipient of the addressee please notify us of receipt by returning the e-mail and do not use, copy, retain, distribute or disclose the information in or attached to the e-mail.
> Any opinions expressed within this e-mail are those of the individual and not necessarily of Diamond Light Source Ltd.
> Diamond Light Source Ltd. cannot guarantee that this e-mail or any attachments are free from viruses and we cannot accept liability for any damage which you may sustain as a result of software viruses which may be transmitted in or with the message.
> Diamond Light Source Limited (company no. 4375679). Registered in England and Wales with its registered office at Diamond House, Harwell Science and Innovation Campus, Didcot, Oxfordshire, OX11 0DE, United Kingdom
________________________________________________________________________
Mauro Giacchini
Control Systems Specialist
INFN Laboratori Nazionali di Legnaro
Viale Università 2
I 35020 Legnaro (Padova)
Tel. +39 049 8068 558
Fax               558
EPICS _at_ LNL http://www.lnl.infn.it/~epics/
...the first EPICS installation to the project SPES realized from the
scratch in ITALY is in production since begin 2010!!
This email has been checked for viruses by Avast antivirus software.
https://www.avast.com/antivirus
RE: Cost effective solution for monitor a large number of temperatures w EPICS austen.rose
RE: Cost effective solution for monitor a large number of temperatures w EPICS Mazanec Tomáš
Re: Cost effective solution for monitor a large number of temperatures w EPICS Jack
Prev: RE: Guide needed in order to work with the EPICS related Git repositories ulrik.pedersen
Next: EPICS Spring meeting Timo Korhonen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Cost effective solution for monitor a large number of temperatures w EPICS Jack
Next: VxWorks 6.9 Stefen Paul
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
