1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Pilatus plugins is not available...
To: [email protected]
Date: Thu, 18 Feb 2016 17:13:02 +0900
Hello...
i use the pilatus detector...
i had setuped a pilatus ioc
but Plugins' pv is not Ok...
Only $(PREFIX):Image1:... 's pv is available..
st.cmd
######################### Pilatus Detector START  ######################################################
#epicsEnvSet("PREFIX", "BL5C")
epicsEnvSet("PILPORT",   "PIL")
epicsEnvSet("QSIZE",  "20")
epicsEnvSet("XSIZE",  "487")
epicsEnvSet("YSIZE",  "195")
epicsEnvSet("NCHANS", "2048")
epicsEnvSet("CAMSERVER", "10.0.1.100")
# Create the asyn port to talk to the Pilatus on port 41234.
drvAsynIPPortConfigure("camserver","$(CAMSERVER):41234")
# Set the input and output terminators.
asynOctetSetInputEos("camserver", 0, "\030")
asynOctetSetOutputEos("camserver", 0, "\n")
drvAsynIPPortConfigure("camserver","10.0.1.100:41234<http://10.0.1.100:41234><http://10.0.1.100:41234>")
#asynSetTraceIOMask("camserver", 0, 2)
#asynSetTraceMark("camserver",0,9)
pilatusDetectorConfig("$(PILPORT)", "camserver", $(XSIZE), $(YSIZE), 50, 200000000)
dbLoadRecords("$(AREA_DETECTOR)/ADApp/Db/ADBase.template", "P=$(PREFIX):,R=cam1:,PORT=$(PILPORT),ADDR=0,TIMEOUT=1")
dbLoadRecords("$(AREA_DETECTOR)/ADApp/Db/NDFile.template", "P=$(PREFIX):,R=cam1:,PORT=$(PILPORT),ADDR=0,TIMEOUT=1")
dbLoadRecords("$(AREA_DETECTOR)/ADApp/Db/pilatus.template","P=$(PREFIX):,R=cam1:,PORT=$(PILPORT),ADDR=0,TIMEOUT=1,CAMSERVER_PORT=camserver")
# Create a standard arrays plugin
NDStdArraysConfigure("Image1", 5, 0, "$(PILPORT)", 0, -1)
dbLoadRecords("$(AREA_DETECTOR)/ADApp/Db/NDPluginBase.template","P=$(PREFIX):,R=image1:,PORT=Image1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=$(PILPORT),NDARRAY_ADDR=0")
dbLoadRecords("$(AREA_DETECTOR)/ADApp/Db/NDStdArrays.template", "P=$(PREFIX):,R=image1:,PORT=Image1,ADDR=0,TIMEOUT=1,TYPE=Int32,FTVL=LONG,NELEMENTS=94965")
asynSetTraceMask("$(PORT)",0,255)
# Load all other plugins using commonPlugins.cmd
< ../commonPlugins.cmd
i can't see the areaDetector plugins is not working..
they are blank...
Can you tell me What is wrong?
Best Regards.
mujin
RE: Pilatus plugins is not available... Mark Rivers
Prev: Re: EPICS reference Jameson Graef Rollins
Next: does not exist, sCalcout.c 梁雅翔
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: Pilatus plugins is not available... Mark Rivers
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
