1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Motor record with encoders
To: "'Henrique Almeida'" <[email protected]>, "[email protected] Talk" <[email protected]>
Date: Thu, 18 Feb 2016 18:59:04 +0000
Yes the motor record can update REP when all motors are stopped.  If you are using a “Model 2” or “Model 3” driver that does callbacks when the motor is idle then the record will automatically process and update.  If you are using a “Model 1” driver then you need to write to the STUP field to force the record to read the status.
From: [email protected] [mailto:[email protected]] On Behalf Of Henrique Almeida
Sent: Thursday, February 18, 2016 12:50 PM
To: [email protected] Talk
Subject: Motor record with encoders
 Hello, is the motor record currently able to update the encoder position ("REP" PV) while all motors are stopped ?
Re: Motor record with encoders Henrique Almeida
Prev: Motor record with encoders Henrique Almeida
Next: Re: Motor record with encoders Henrique Almeida
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
