1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Motor examples missing devSequencer
To: Benjamin Franksen <[email protected]>
Cc: [email protected]
Date: Tue, 23 Feb 2016 15:49:40 +0100
On Tue, 23 Feb 2016 15:06:56 +0100 Benjamin Franksen
<[email protected]> wrote about Re: Motor examples
missing devSequencer:
Hello Ben,
BF> To answer your original question: Version 2.2 of the sequencer no
BF> longer has the devSequencer device support. You should be able to
BF> proceed with seq-2.2.3 by deleting the offending line from
BF> PI_GCS2Support.dbd . If the latter file is generated by make and not a
BF> source file, remove the line saying "DBD_whatever += devSequencer.dbd"
BF> from the Makefile. You probably also need to remove a line that says
BF> something like "xxx_LIBS += devSequencer" from the Makefile.
I was able to compile everything cleanly with the new sequencer using the
development version of the motor record as suggested by Mark.
Now I just need to understand how to use all this for the AG_UC motor
hardware I have here. I found an example st.cmd.AG_UC that finds the
controller and creates some channels... what part of the documentation is
the next suggested read?
cu
  Gerrit
RE: Motor examples missing devSequencer Mark Rivers
Motor examples missing devSequencer Gerrit Kühn
Re: Motor examples missing devSequencer Benjamin Franksen
Prev: Re: How to cs-studio Scan System Kasemir, Kay
Next: RE: Motor examples missing devSequencer Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Motor examples missing devSequencer Benjamin Franksen
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
