1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: drvAsynSerialPort + RS485
To: Florian Feldbauer <[email protected]>, EPICS Tech-Talk <[email protected]>
Date: Thu, 25 Feb 2016 13:23:54 +0000
I think that adding additional asynOption key/value pairs for RS-485 to the existing driver would be OK.  These can be implemented with ioctl calls after the device is opened, so it does not require changing the syntax of drvAsynSerialPortConfigure.  Here is an example of how to do it:
https://www.kernel.org/doc/Documentation/serial/serial-rs485.txt
Sent: Thursday, February 25, 2016 7:11 AM
To: EPICS Tech-Talk
Cc: Mark Rivers
Subject: drvAsynSerialPort + RS485
Hey all,
we are using an ADM2682 RS485 transceiver connected to a BeagleBone Black.
Data exchange is done via one of the uart interfaces. Data direction is
set by a GPIO
from kernel space.
Is there currently a driver available for EPICS for RS485?
Most settings could be done over the drvAsynSerialPort driver,
but for RS485 one also needs to set the struct serial_rs485 which is not
implemented in this driver.
Does it make sense to add an option to use RS485 support?
Or would it be better to create a clone of the serial port driver for RS485?
Best regards,
Florian
| Dr. Florian Feldbauer                |
| Helmholtz-Institut Mainz /           |
| Johannes Gutenberg-Universität Mainz |
| Johann-Joachim-Becher-Weg 36         |
| D-55128 Mainz                        |
| Office: SB1 / 00-213                 |
| Phone:  (+49)6131 / 39-29608         |
Re: drvAsynSerialPort + RS485 Florian Feldbauer
Prev: drvAsynSerialPort + RS485 Florian Feldbauer
Next: Re: drvAsynSerialPort + RS485 Florian Feldbauer
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
