1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Raspberrypi GPIO access through EPICS
To: vivek singh <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 2 Mar 2016 05:44:24 +0000
I would recommend that you use the asynPortDriver C++ base class to write a driver.  You then don't need to write any device support, just a driver.
This page describes asynPortDriver.
http://www.aps.anl.gov/epics/modules/soft/asyn/R4-29/asynPortDriver.html
It contains a link to the following document that is an introductory talk on how to write a driver using asynPortDriver.  This example includes doing simply binary and analog I/O.
https://subversion.xray.aps.anl.gov/synApps/measComp/trunk/documentation/measCompTutorial.pdf
In this example the driver is making calls to the Measurement Computing library to do the I/O, but you would just substitute the C calls you have for the GPIO.
From: [email protected] [[email protected]] on behalf of vivek singh [[email protected]]
Sent: Tuesday, March 01, 2016 11:02 PM
To: [email protected]
Subject: Raspberrypi GPIO access through EPICS
Hello all,
I want to access my Rapberrypi GPIO through EPICS. I had refered some documents which suggested to write device support and driver for it. Can you please suggest me from where to start and how?  And if possible send me some examples for accessing GPIO.
I have a programm in C and python which can toggle raspberry pi GPIO, What are the ways to do that through epics?
[https://ssl.gstatic.com/ui/v1/icons/mail/images/cleardot.gif]
-regards
 Vivek
Re: Raspberrypi GPIO access through EPICS Florian Feldbauer
Raspberrypi GPIO access through EPICS vivek singh
Prev: Raspberrypi GPIO access through EPICS vivek singh
Next: Re: Raspberrypi GPIO access through EPICS Florian Feldbauer
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
