1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Array of strings with asyn?
Date: Mon, 7 Mar 2016 22:25:34 -0600
I'm wondering how best to model the following situation....
I have a number of DS18B20 temperature sensors on a OneWire serial bus controlled by an Arduino Mega. A Raspberry Pi runs an IOC and communicates with the Arduino via asyn. In other words, I'm implementing a smaller version of the solution I suggested back in January to measure a large number of temperatures.
Each of these sensors has the equivalent of a unique MAC address that is 8 bytes long, and the sensors can be hot swapped on the bus. I'd like an operator to be able to retrieve these. I can easily have the Arduino scan the bus and create a list of addresses. I'm just not sure how to get that info back to the IOC.
I know I can create individual stringin records for the 1st, 2nd, 3rd. etc. address that was scanned, up to a defined maximum limit of temperature sensors, and have the Arduino return these as hex formatted strings. But I'm wondering if there's a better way.
Ideally, I'd like it to be returned as an array of type stringin. But I don't know if such a thing exists in EPICS, or if it does, how to pass it through asyn.
I can't return it as a single space or comma delineated string either, since I exceed the 40 character limit with 3 devices.
I considered trying to pass these in binary form and convert it as hex for operator display, but I don't know if a 64 bit datatype exists.
Is this something that a waveform record could do? If so, could CSS Boy display this as some kind of box or list of strings?
Ryan
P.S. Latest EPICS controlled beer brewing update: As I mentioned last September, I had been stalled waiting for a CNC mill at a hackerspace to be repaired so that I could easily do precision drilling for the 60+ holes I need to mount jacks on a control box. The mill still doesn't work, but I found a better solution: a friend with a waterjet cutter. It made short work of cutting all those holes, as well as a panel insert for more DIN rails. So things are progressing.... Update here: http://www.mackenziegems.com/2016/02/21/cnc-beer-part-3-fusion-360-and-waterjet-overkill/
Re: Array of strings with asyn? Michael Davidsaver
RE: Array of strings with asyn? Mark Rivers
Prev: Re: mrfioc2 error at uTCA platform Konrad, Martin
Next: Re: Array of strings with asyn? Michael Davidsaver
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Problem in running simple tutorial problems Matt Newville
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
