Hi all,
I should mention again I have no prior experience in working with
epics or any server.
So my naive first thought was that:
In [1]: import epics
In [2]: p = epics.PV('LargeWaveform')
should start a server and create the PV, which is apparently not the
case...?
So I started a "SimpleServer" using PCASpy. But here all PVs need to
be defined before starting the server (correct?)?
I was able to modify the data in these pre defined PVs with pre
defined array sizes.
Yet I want to be able to store arrays of unknown/changing size in
these PVs!
So to sum up:
How do I start an epics server? Is it possible to create PVs during
operation/how? How do I store arrays of arbitrary size in them?
From what I gather from the wiki all this should be possible, but I
seem to be missing a step...
(I'm working locally so firewall should not be an issue for now...)
Thanks in advance,
Jan
On Mon, 7 Mar 2016 10:44:45 -0600
Matt Newville <[email protected]> wrote:
Hi Jan,
On Mon, Mar 7, 2016 at 7:43 AM, Jan Cedric Hönig <
I'm planning to use epics, but I"m stuck right at the beginning.
I work on scientific linux 6 so first I start python:
ipython
Python 2.7.5 (default, Jun 5 2014, 14:38:05)
Then I try simple epics commands:
In [3]: p.connect
Out[3]: <bound method PV.connect of <PV 'LargeWaveform': not
connected>>
But I am unable to connect any of my PVs. Am I doing something
wrong?
'connect' is a method of a PV. To run this method, add parens:
p.connect()
The connection should happen automatically and soon, so that you
don't need
to explicitly run the connect method, and can just access the data:
p.get()
You can also checked the value of `p.connected`, which will be True
once
(and if) the PV is connected.
--Matt
- Re: Problem in running simple tutorial problems Matt Newville
- Problem in running simple tutorial problems Jan Cedric Hönig
CSS write buffer size 吴煊
RE: Array of strings with asyn? Mark Rivers
<2016>
2025
<2016>
2025
