1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: mbbo/mbbi and bits subset
To: "[email protected]" <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 10 Mar 2016 11:35:02 +0000
Hi Gennaro,
You can do what you want using the asynUInt32Digital support and the @asynMask INP syntax.
record(mbbo,"Acquire") {
    field(DTYP,"asynUInt32Digital")
    field(OUT,"@asynMask(myPort , 0, 0x3 , 1.0) ")
    field(ZRST,"Start acquire")
    field(ONST,"Stop acquire")
    field(ZRVL,"0x2")
    field(ONVL,"0x3")
You can use multiple mbbo/mbbi records to access different adjacent bits in your register using this technique.
The asyn device support uses the NOBT, SHFT, and MASK fields of the mbbo/mbbi records documented here:
https://wiki-ext.aps.anl.gov/epics/index.php/RRM_3-14_Multi-Bit_Binary_Output
From: [email protected] [[email protected]] on behalf of [email protected] [[email protected]]
Sent: Thursday, March 10, 2016 4:54 AM
To: [email protected]
Subject: mbbo/mbbi and bits subset
I'm using mbbo and mbbi record types to write and read
some registers from/to ASYN driver I'm developing;
some registers refers to a single aspect of acquisition
(e.g. channel threshold) and with a simple mbbo record
to write and a mbbi record to read back, everything works
fine...
other registers refers to a setup/control functions
and using the same mbbo/mbbi approach works fine if
the user address (read/write) every time the whole register;
I know mbboDirect for bitwise access of a record value but
is there a method to address (read/write) through a record
a "bits subset" of a "main" mbbo record ?
e.g. acquisition control:
bit[16...2] <don't care>
bit[1...0]
11 stop acquisition
10 start acquisition
01 do something...
00 do something...
which is a simple method to access "directly" bitset [0...1]
in order to have a record I can use to write 11 (3) to stop acquisition,
10 (2) to start acquisiton and so on ?
Thanks in advance,
Gennaro
Gennaro Tortone
INFN Napoli
Italy
tel: +39 81 676169
"Computer Science is no more about computers
than astronomy is about telescopes."
- Edsger Dijkstra
RE: mbbo/mbbi and bits subset [email protected]
Prev: mbbo/mbbi and bits subset [email protected]
Next: RE: mbbo/mbbi and bits subset peter.owens
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: mbbo/mbbi and bits subset [email protected]
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
