I'm a student of Tsinghua University and I have a problem about installing areaDetector. I have already installed synApps and base , the asyn is in the synApps . I want to use PointGrey camera so I want to install an another areaDetector because the one in synApps didn't have Point Grey driver . But after I changed the path and others just like the INSTALL_GUIDE.md said , there is a mistake when I tpye "make". It says "/disk1/epics/distrib/synApps_5_7/support/areaDetector-1-9-1/ADApp/simDetectorSrc/O.linux-x86_64/simDetectorApp_registerRecordDeviceDriver.cpp:607: undefined reference to `pvar_func_NDFileMagickRegister' collect2: error: ld returned 1 exit status" At first , it can not find files "libbusy.a" and something like that.So I copied those file into the folder areaDetector/lib/linux-x86_64 , and it worked. I have already defined support and its subdirectories and I think these problems should not happen . I hope ypu can solve my problem . Thank you!
ANJ, 15 Jul 2016 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
