1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Question about the softioc connection refused ?
To: lzfneu <[email protected]>, "[email protected]" <[email protected]>
Date: Sat, 19 Mar 2016 12:55:02 +0000
Hi Zhefu
> I edited the Koyo1.cmd file to change the ip address in function with two conditions:
> 1) drvAsynIPPortConfigure("Koyo1","127.0.0.1:5065",0,0,1)
> where 127.0.0.1:5065 is my localhost ip address.
This is not correct.  You have specified port 5065 for the drvAsynIPPort driver that is supposed to connect to a Modbus server.  Port 5065 is not used for Modbus, it is used for EPICS channel access.
You cannot run the test application in the Modbus directory unless you actually have a Modbus server that you can connect to.  Do you actually have a Modbus server?  If so, then you specify its IP address and port 502 in the drvAsynIPPortConfigure command.
From: [email protected] [[email protected]] on behalf of lzfneu [[email protected]]
Sent: Saturday, March 19, 2016 7:26 AM
To: [email protected]
Subject: Question about the softioc connection refused ?
hi,
I have encountered another softioc connection problem:
I have insatlled modbus-R2-8, and want to run test example (file named Koyo1.cmd)  in the iocTest folder.
2) drvAsynIPPortConfigure("Koyo1","192.168.1.255:5065",0,0,1)
where 192.168.1.255:5065 is my broadcast ip address that obtained by command ifconfig.
after starting the ioc:
$ modbusApp Koyo1.cmd
the results are both two ip address cannot connect the Koyo1, the error messages are shown below:
2016/03/19 19:40:19.158 Can't connect to 127.0.0.1:5065: Connection refused Koyo1 -1 autoConnect could not connect
2016/03/19 20:19:49.083 Can't connect to 192.168.1.255:5065: Network is unreachable Koyo1 -1 autoConnect could not connect
I am new in epics, could you plesase help me and thanks in advance.
Best regards
Zhefu
RE: Question about the connection refused lzfneu
Question about the softioc connection refused ? lzfneu
Prev: Question about the softioc connection refused ? lzfneu
Next: caget pv with a space 梁雅翔
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: Question about the connection refused lzfneu
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
