1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: error return from ao device support
Cc: "[email protected]" <[email protected]>, "[email protected]" <[email protected]>
Date: Sat, 26 Mar 2016 00:37:43 +0700
Hi Andrew,
Yes, I had already found some old code of mine with recGlbSetSevr, and it worked fine, which is why I cancelled my post to tech-talk.
However, application developers guide does not mention this under the device support description (unless I missed it) perhaps it should be there.
Are you saying that when an error is detected in dev support it should still return ok????
I think record support returns -1 when it detects an error, if so should dev support not do the same?
anyway, as I said, no longer a problem for me :)
thanks
Steve
On 26 Mar 2016, at 00:08, Andrew Johnson <[email protected]> wrote:
> Hi Steve,
> On 03/25/2016 01:38 AM, [email protected] wrote:
>> It seems to me that when ao device support returns error to record
>> support (for instance when the write to the hardware failed) STAT and
>> SEVR get put to NO_ALARM anyway!  so applications have no way to know
>> the write failed.   Is this a bug or feature?
> Where did you read that device support can return an error status like
> that? Any such documentation is wrong and I'd like to fix it. If device
> support needs to flag an alarm it is supposed to put the record into
> alarm state itself by calling
>    recGblSetSevr(prec, stat, sevr);
>> When ai device support returns error, STAT and SEVR  indicate an
>> error.
>> I am using 3.14.12.2
> I don't see any difference between the way the ai and ao records handle
> return status values from the read_ai() / write_ao() support routines,
> and I certainly don't see code to do what you're describing. However if
> an ai device has never actually returned a value the UDF field will
> still be set so there will be a UDF_ALARM. UDF just means that the value
> in the VAL field is invalid and should not be used (it also gets set
> when VAL contains a NaN).
> Any error status from the device support read/write routine is passed
> back up to the IOC by process(), but with the exception of the don't
> convert behaviour from input records the status doesn't really mean or
> do anything. It can make it back to a CA client as an exception which
> could confuse your users, so the support routine should probably only
> ever return 0 (or 2 for input record types).
> HTH,
> - Andrew
> There are only two hard problems in distributed systems:
>  2. Exactly-once delivery
>  1. Guaranteed order of messages
> -- Mathias Verraes
Re: error return from ao device support Michael Davidsaver
Re: error return from ao device support Andrew Johnson
Prev: Re: error return from ao device support Andrew Johnson
Next: Re: error return from ao device support Michael Davidsaver
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
