Hi everyone,
I have a strange question.
I use the stream and asyn to control a device. epics 3.1.12.5,synApp_5_8.
I set the baud of serial in 115200 in st.cmd with these commands:
epicsEnvSet "TTY" "$(TTY=/dev/ttyS1)"
drvAsynSerialPortConfigure("L0","$(TTY)",0,0,0)
asynSetOption("L0",-1,"baud","115200")
asynSetOption("L0",-1,"bits","8")
asynSetOption("L0",-1,"parity","none")
asynSetOption("L0",-1,"stop","1")
asynSetOption("L0",-1,"clocal","Y")
asynSetOption("L0",-1,"crtscts","N")
asynOctetSetInputEos("L0",-1,"\r\n")
asynOctetSetOutputEos("L0",-1,"\r\n")
asynSetTraceIOMask("L0",-1,0x2)
asynSetTraceMask("L0",-1,0x9)
Then I start the st.cmd and communicate it with another xp computer, using Serial port assistant.
I found that I received the right information only when I set the baud rate was 9600. It get nothing when the baud rate was 115200.
And it should be 115200, I failed when i used it in device directly.
I did set it was 115200 in st.cmd, why it did not work.
Liang yx
- RE: set baud rate not work Mark Rivers
- RE: set baud rate not work Mark S. Engbretson
Re: Multiple layers of DB templates? Andrew Johnson
Controlling vacuum valves with EPICS Florian Feldbauer
<2016>
Re: Multiple layers of DB templates? Konrad, Martin
<2016>
