1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Controlling vacuum valves with EPICS
To: EPICS Tech-Talk <[email protected]>
Date: Tue, 5 Apr 2016 11:06:47 +0200
Hi Florian,
it's common to combine the functionality of controlling the valves with
some kind of interlock functionality.
If some vacuum sensors in a vacuum sector report bad conditions the valves
of the vacuum sector should be closed as fast as possible to prevent the venting
of larger areas.
This job should be done in a safe manner.
PLCs are available as Safety-PLCs and a therefore good choice to do this job.
Cheers,
Joachim
On 05.04.2016 09:52, Florian Feldbauer wrote:
> Hey all,
> I'm working with EPICS now for several years to develop parts of the Detector Control System for
> the PANDA experiment.
> For our luminosity detector we need to control a small vacuum system.
> I had a look at various talks from EPICS meetings to see, how others are building their control systems
> and I have a question concerning this:
> All the systems I have seen are using PLCs to control the valves of the system.
> What is the advantage of a PLC for controlling the valves?
> Why not using an EPICS IOC for direct control running on a realtime system?
> I never worked on vacuum systems before, and our vacuum workshop here at Mainz
> could not help me with this question.
> Many thanks in advance for the help!
>   Florian
Controlling vacuum valves with EPICS Florian Feldbauer
Prev: Controlling vacuum valves with EPICS Florian Feldbauer
Next: RE: set baud rate not work Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: Controlling vacuum valves with EPICS Mark Rivers
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
