1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: PointGrey's image is always black
To: 彭毛毛 <[email protected]>
Cc: EPICS Tech-Talk <[email protected]>
Date: Thu, 7 Apr 2016 12:54:43 +0000
I am posting this to tech-talk because it is bouncing when I sent it directly to the recipient at Tsinghua University.  Hopefully they will see it on tech-talk and also fix the e-mail problem at their end.
Sent: Thursday, April 07, 2016 7:51 AM
To: 彭毛毛
> First, when I set 13PG1:cam1:Acquire to zero, OPI stopped getting picture from IOC. But is IOC still getting pictures from the camera at this time?
No, when you set Acquire to zero the IOC tells the camera to stop sending images.
> Second, how to modify the IOC to have two or even more cameras to work at the same time?
I would recommend running each camera in its own IOC.  These can be on the same computer.
> Third, sometimes the IOC might disconnect with the camera with no reason. It just disconnected , and when I restart the IOC , it says :
I have not seen that problem.  If you power-cycle the camera will the IOC find it then?
I tried to send you messages last week but they kept being rejected on your end.
Sent: Wednesday, April 06, 2016 10:17 PM
To: Mark Rivers
Subject: PointGrey's image is always black
Hi ,Mark
My camera is working now ! Thank you !The image was black because the EPICS_
But I still have three questions.
pointGreyConfig("PG1", 15287716, 0x1, 1)
2016/04/07 11:04:04.227 pointGrey:connectCamera: no cameras found
2016/04/07 11:04:04.227 pointGrey:connectCamera: ERROR calling GetCameraFromSerialNumber Type=19 Description=Failed to get the camera from the serial number.
2016/04/07 11:04:04.227 pointGrey:pointGrey:  camera connection failed (3)
Number of cameras detected: 0
2016/04/07 11:04:04.229 pointGrey:connectCamera: no cameras found
2016/04/07 11:04:04.229 pointGrey:connectCamera: ERROR calling GetCameraFromSerialNumber Type=19 Description=Failed to get the camera from the serial number.
2016/04/07 11:04:04.229 pointGrey::report error calling connectCamera()
Supported properties
Segmentation fault (core dumped)
But when I start flycap ,the camera is function well and IOC will also function well just after closing flycap . I have set Packet size to 1440 and Packet Delay to 600 . I think it's big enough.
Thank you !
Maomao Pam
Prev: Re: Multiple layers of DB templates? Konrad, Martin
Next: EPICS VxWorks driver for the Acromag IP-521 module Estes, Chris
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Training on asyn and areaDetector at the EPICS Collaboration Meeting Mark Rivers
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
