1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: the way pv sent to serial changed
To: l123173 <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 13 Apr 2016 11:03:16 +0000
I am not sure I understand what you mean.
Can you send some specific examples of commands you send to change the speed, and then another command that must contain the speed?
From: [email protected] [[email protected]] on behalf of l123173 [[email protected]]
Sent: Tuesday, April 12, 2016 10:02 PM
To: [email protected]
Subject: the way pv sent to serial changed
Hi everyone ,
   I use 'epics 3.14.12.1 in linux' + asyn + stream + CSS.
   I controled the motor through serial.  Now I want to change a pv through CSS and then send it to serial.‍
   I mean these, For example:
   I set speed value 2 in CSS. Then all command about moving motor should send the string contain the speed value to‍ serial,like xxxx2
   When I set speed value 3 in CSS, all command sent to serial should contain 3, like xxx3.
   No need to change the xxx.proto file and make which is the way I use now , it is very inconvenient.
Could you introduce me a much better way.
Li X
the way pv sent to serial changed l123173
Prev: the way pv sent to serial changed l123173
Next: RE: Re:RE: Re:RE: the way pv sent to serial changed Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
