1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: Force one record to run before all others
To: [email protected]
Date: Thu, 14 Apr 2016 12:30:07 -0400
On 04/14/2016 12:13 PM, Andrew Johnson wrote:
> you may have to
> include the ADR command in the Stream protocol as part of every command
You might get some ideas by looking at "I need to write more than one
value in one message" part C.
http://epics.web.psi.ch/software/streamdevice/doc/tipsandtricks.html#writemany
Something like
>  field(OUT, "@TDK_Lambda_Genesys.proto writecmd($(P),ID) $(PORT)")
Then in .proto
> writecmd {
>   out "ADDR %(\$1:ADDRESS.VAL)s; \$2 %f;";
This example also uses "Protocol arguments".
http://epics.web.psi.ch/software/streamdevice/doc/protocol.html#argvar
Force one record to run before all others kathryn.baker
Re: Force one record to run before all others Andrew Johnson
Prev: RE: Force one record to run before all others kathryn.baker
Next: Device support for Copley Controls Xenus Vigder, Mark
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025
ANJ, 15 Jul 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
