1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: IOC segmentation fault related to CA security
To: "[email protected] list" <[email protected]>
Date: Fri, 15 Apr 2016 21:27:47 +0000
I’ve had a few instances of one of my soft IOCs crashing with a segmentation fault when I shutdown another IOC that hosts a PV used as part of the CA security logic on the other crashed IOC.
There is sometimes (but not always) this message printed out before the crash:
dbCa:exceptionCallback stat "Virtual circuit disconnect" channel "unknown" context "cg1d-dassrv1.ornl.gov:5064"
nativeType DBR_invalid requestType DBR_invalid nativeCount 0 requestCount 0 noReadAccess noWriteAccess
Printing the stack trace:
Core was generated by `../../bin/linux-x86_64/cg1d-parker1 ./st.cmd'.
Program terminated with signal 11, Segmentation fault.
#0  0x00007f5321218599 in ellDelete (pList=0x7f52bc000920, pNode=0x7f52ac008ec0) at ../../../src/libCom/ellLib/ellLib.c:87
87              pNode->previous->next = pNode->next;
Missing separate debuginfos, use: debuginfo-install glibc-2.12-1.149.el6_6.9.x86_64 libgcc-4.4.7-11.el6.x86_64 libstdc++-4.4.7-11.el6.x86_64 ncurses-libs-5.7-3.20090208.el6.x86_64 readline-6.0-4.el6.x86_64
(gdb) bt
#1  0x00007f532217c289 in casAccessRightsCB (ascpvt=0x7f52b8000db8, type=asClientCOAR) at ../camessage.c:1111
#2  0x00007f5321d64122 in asComputePvt (asClientPvt=0x7f52b8000db8) at ../asLibRoutines.c:1014
#3  0x00007f5321d63ea0 in asComputeAsgPvt (pasg=0x1f91ee0) at ../asLibRoutines.c:940
#4  0x00007f5321d62419 in asComputeAsg (pasg=0x1f91ee0) at ../asLibRoutines.c:455
#5  0x00007f5321d60482 in connectCallback (arg=...) at ../asCa.c:99
#6  0x00007f53214c1301 in oldChannelNotify::disconnectNotify (this=0x7f52d0000d10, guard=...) at ../oldChannelNotify.cpp:112
#7  0x00007f53214abe30 in nciu::unresponsiveCircuitNotify (this=0x7f5323714010, cbGuard=..., guard=...) at ../nciu.cpp:171
#8  0x00007f53214b7c38 in tcpiiu::disconnectAllChannels (this=0x7f52d40008c0, cbGuard=..., guard=..., discIIU=...) at ../tcpiiu.cpp:1834
#9  0x00007f532149a042 in cac::destroyIIU (this=0x7f52d000ed20, iiu=...) at ../cac.cpp:1227
#10 0x00007f53214b27e3 in tcpSendThread::run (this=0x7f52d4000a00) at ../tcpiiu.cpp:229
#11 0x00007f532122bc51 in epicsThreadCallEntryPoint (pPvt=0x7f52d4000a08) at ../../../src/libCom/osi/epicsThread.cpp:85
#12 0x00007f53212333ce in start_routine (arg=0x7f52d400a250) at ../../../src/libCom/osi/os/posix/osdThread.c:385
#13 0x00007f53204a29d1 in start_thread () from /lib64/libpthread.so.0
#14 0x00007f53207a08fd in clone () from /lib64/libc.so.6
The crashed IOC has a CA access security rule that looks like:
ASG(DEFAULT)
    INPA("$(P):Scan:Active")
    RULE(1, READ)
    RULE(1, WRITE)
        CALC("A=0")
    RULE(1, WRITE)
        UAG(epics, beamline, detector)
        HAG(beamline)
        CALC("A=1")
where $(P):Scan:Active is hosted by the IOC that I’m shutting down.
In addition there is a channel access link between the two IOCs involving a CP link.
I can’t reliably reproduce it, but it’s happened a few times today as I was testing it (stopping and starting the IOC hosting $(P):Scan:Active perhaps 20 times).
Anybody have ideas about this?
Our base version is 3.14.12.4 running on RHEL6.
Cheers,
Matt
Data Acquisition and Control Engineer
Spallation Neutron Source
Oak Ridge National Lab
Re: IOC segmentation fault related to CA security Michael Davidsaver
Prev: Device support for Copley Controls Xenus Vigder, Mark
Next: Re: IOC segmentation fault related to CA security Michael Davidsaver
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
