1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Problem with areaDetector NDFile FilePath setting
To: [email protected]
Date: Mon, 18 Apr 2016 11:33:46 +0200
Hi Jörn,
In BOY set PV Name property like this:
$(P)$(R)FilePath {"longString":true}
Hope this helps,
Hinko
On 04/18/2016 08:39 AM, Jörn Wüstenfeld wrote:
Hello,
I'm trying to setup an areaDetector IOC for reading a Basler camera. The
basics are working, but I have problems to setup the file writing.
Regardless of what way I use (CSS/BOY or caput) I get an exception if I try to
setup any of the Filename related PV's (FilePath, FileName, FileTemplate).
In NDFile.template they are defined as waveform records while BOY interpretes
them as STRING.
If I do:
--> cainfo areaDetector:HDF1:FilePath
     State:            connected
     Host:             x.x.x.x:5064
     Access:           read, write
     Native data type: DBF_CHAR
     Request type:     DBR_CHAR
     Element count:    256
If I try to set the variable to some path:
caput areaDetector:HDF1:FilePath "/home/<some user>"
Old : areaDetector:HDF1:FilePath 256 3 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
0
CA.Client.Exception...............................................
     Warning: "Channel write request failed"
     Context: "op=1, channel=areaDetector:HDF1:FilePath, type=DBR_STRING,
count=1, ctx="areaDetector:HDF1:FilePath""
     Source File: ../oldChannelNotify.cpp line 160
     Current Time: Mon Apr 18 2016 08:18:01.581943010
New : areaDetector:HDF1:FilePath 256 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
0
Only if I use caput -S ... I can successfully set the variable.
In CSS I get the following message:
2016-04-18 08:15:44 ERROR: Failed to write value to PV
areaDetector:HDF1:FilePath from widget Text Input.
Illegal input : /home/<some user>
java.lang.ArrayIndexOutOfBoundsException: 0
How to force BOY to send the string as an array of chars?
Regards
Jörn
Problem with areaDetector NDFile FilePath setting Jörn Wüstenfeld
Prev: Problem with areaDetector NDFile FilePath setting Jörn Wüstenfeld
Next: seqence update, then make motor error l123173
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
