1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: Script BOY IntensityGraph to show areaDetector output of variable size
To: Phil Atkin <[email protected]>
Date: Wed, 20 Apr 2016 09:26:42 -0400
Hi Phil,
You can create two rules, for the data_width and data_height properties, that look at the $(P)ArraySize0_RBV and $(P)ArraySize1_RBV PV's
HTH,
Bruno
On Wed, Apr 20, 2016 at 6:44 AM, Phil Atkin <[email protected]> wrote:
Thanks Gabriela,
- but I guess my question was ambiguous.  If I understand correctly, your script adjusts the height of the IntensityGraph widget so that its aspect ratio matches the image.
But the IntensityGraph will not display anything at all unless I set its Data Height and Data Width properties to match the attached array.  Do you have something to accomplish this?
Also: I have no idea how to actually attach the code or make it run at an appropriate time.  Can you point me at documentation that describes this?
Thanks
Phil
On 20/04/2016 11:34, [email protected] wrote:
this is the very simple python script that I use:
from org.csstudio.opibuilder.scriptUtil import PVUtil
imageWidget        = display.getWidget('Image')
imageXSizeWidget   = display.getWidget('X-Size')
imageYSizeWidget   = display.getWidget('Y-Size')
try :
    imageXSizePV   = imageXSizeWidget.getPV()
    imageYSizePV   = imageYSizeWidget.getPV()
    nImageRows    = PVUtil.getLong(imageYSizePV)
    nImageColumns = PVUtil.getLong(imageXSizePV)
    imageWidget.setPropertyValue('graph_area_width', 512)
    imageWidget.setPropertyValue('graph_area_height', (512.0/nImageColumns)*nImageRows)
except :
    pass
Phil Atkin <[email protected]> ha scritto:
I'm using BOY IntensityGraph to show a (stdArray) output image from an areaDetector driver/plugin.
The size of my array changes quite a bit.
Can someone tell me (in laborious detail if necessary, please) how to set up scripts or "embedded rules" on the IntensityGraph to cope with a variable-sized image?
Thanks!
Phil
Re: Script BOY IntensityGraph to show areaDetector output of variable size Pearson, Matthew R.
Re: Script BOY IntensityGraph to show areaDetector output of variable size gabriele . salvato
Re: Script BOY IntensityGraph to show areaDetector output of variable size Phil Atkin
Prev: Re: Script BOY IntensityGraph to show areaDetector output of variable size Phil Atkin
Next: How to use registry to replace vxWorks symLib? Michael Westfall
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025
Next: Re: Script BOY IntensityGraph to show areaDetector output of variable size Pearson, Matthew R.
ANJ, 15 Jul 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
