1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: calc question
Date: Wed, 27 Apr 2016 04:04:04 +0000
Perhaps it was discussed previously,
For a current measuring instrument (i404), I am setting measuring range from mbbo record.
record(mbbo, "$(Sys)$(Dev)Cmd:Rng-Sel") {
  field(VAL, "1.0e-9")
  field(ZRST, "1.0e-9")
  field(ONST, "8.0e-9")
  field(TWST, "1.0e-8")
  field(THST, "1.0e-7")
  field(FRST, "1.0e-6")
  field(FVST, "1.0e-5")
  field(SXST, "2.0e-5")
  field(FLNK, "$(Sys)$(Dev)Cmd:Rng-Calc")
  field(DESC, "SELECTION OF CURRENT RANGES")
record(calc, "$(Sys)$(Dev)Cmd:Rng-Calc") {
  field(SCAN, "Passive")
  field(A, "1.0e-9")
  field(B, "8.0e-9")
  field(C, "1.0e-8")
  field(D, "1.0e-7")
  field(E, "1.0e-6")
  field(F, "1.0e-5")
  field(G, "2.0e-5")
  field(INPH, "$(Sys)$(Dev)Cmd:Rng-Sel")
  field(CALC, "(H=0)?A:(H=1)?B:(H=2)?C:(H=3)?D:(H=4)?E:(H=5)?F:G")
  field(FLNK, "$(Sys)$(Dev)Val:Rng-SP")
record(ao, "$(Sys)$(Dev)Val:Rng-SP") {
  field(FLNK, "$(Sys)$(Dev)Cmd:CapChk-Calcout")
  field(OMSL, "closed_loop")
  field(OIF, "Full")
  field(DOL, "$(Sys)$(Dev)Cmd:Rng-Calc.VAL")
  field(EGU, "A")
This seems to work quite well, but there has to be a better way than CALC 'switch'. Anyone has a better solution?
Kazimierz
RE: calc question Mooney, Tim M.
Prev: Re: EPICS_TIMEZONE and TZ on RTEMS Matt Rippa
Next: RE: calc question Mooney, Tim M.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: AW: Connection to Siemens S7 PLC Mueller, Joachim
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
