Hi Li,
These messages look like the pv name is indeed wrong.
If you do a "dbl" on your IOC - is the pv name that you want to
reach really "${pv}"? That looks quite unusual.
Make sure you don't have spaces or illegal characters in the pv on
the caget/cainfo command line.
Are you using the CA command line tools on the same host as the
IOC, or on a different machine?
Cheers,
~Ralph
On 27/04/2016 10:24, l123173 wrote:
Hi all,
I wonder why I failed and got message " Channel connect
time out: ${pv} not found " or camonitor "*** Not connected
(PV not found)", when I use caget, caput, camonitor.
I added the path to environment and I can move the motor
successfully with my ioc and the pv name isn't wront.
Could you give some suggestion?
Li x
- caget always not found l123173
AW: Connection to Siemens S7 PLC Rekow, Jens
Re: AW: Connection to Siemens S7 PLC Remi Faure
<2016>
Fw:Re:Re: caget always not found l123173
<2016>
ANJ, 15 Jul 2016 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
