1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Question about relational database setup ?
To: lzfneu <[email protected]>
Date: Thu, 28 Apr 2016 12:54:16 +0000
You need the read the complete guide, including chapter 4 on Compiling, Running, Debugging CSS, http://cs-studio.sourceforge.net/docbook/ch04.html, and not just jump to chapter 11 for the RDB-based archive system and then wonder why it doesn’t make sense when taken out of context.
If you read chapter 4, you’ll have the source code and find the dbd folder in there, https://github.com/ControlSystemStudio/cs-studio/tree/master/applications/archive/archive-plugins/org.csstudio.archive.rdb/dbd
-Kay
> On Apr 28, 2016, at 3:15 AM, lzfneu <[email protected]> wrote:
> Hi,
>   I try to create the table structure in MySQL RDB,  i have consult the manual "Control System Studio Guide"  which says the commands for creating RDB table structures are in files in dbd sub-directory of the plugin org.csstudio.archive.rdb.
>   In the plugins folder of control system studio i find an jar folder named org.cssstudio.archive.rdb_4.0.0.201507131348.jar which
> contains two files under rdb folder: "Activator.calss" and "RDBArchievPreferences.class" ,but i don't know how to use them to create table structures by using one of the files.
>   I am novice in using control system studio, could any one help me, thanks in advance !
> Zhefu
Question about relational database setup ? lzfneu
Prev: Re: stream Device I/O error Heinz Junkes
Next: Re: stream Device I/O error Heinz Junkes
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Question about relational database setup ? lzfneu
Next: Upgrade calc module to EPICS 3.16 Henrique Almeida
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
