1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: stream Device I/O error
To: Eric Norum <[email protected]>
Date: Thu, 28 Apr 2016 20:51:11 +0000
Hi Eric,
This 'trick' overcomes the limitation of finite string size.
For completeness, I include the relevant parts of db, and .proto files.
getGains {out "CALIB:GAI?"; in "CALIB:GAI?\10\06"
	 "%(\$1Gain:Sts-RB)d,"
	 "%e,"
	 "%(\$1Gain:2-RB.VAL)e,"
	 "%(\$1Gain:3-RB.VAL)e,"
	 "%(\$1Gain:4-RB.VAL)e,"
	 "%(\$1Gain:5-RB.VAL)e,"
	 "%(\$1Gain:6-RB.VAL)e,"
	 "%(\$1Gain:7-RB.VAL)e,"
	 "%(\$1Gain:8-RB.VAL)e";
	 InTerminator = CR LF; }
record(ai, "$(Sys)$(Dev)Gain:1-RB") {
  field(DESC, "COMPENSATION FACTOR A IN")
  field(DTYP, "stream")
  field(INP, "@I404.protocol getGains($(Sys)$(Dev)) $(PORT) 0")
  field(PINI, "YES")
  field(SCAN, "Passive")
record(ai, "$(Sys)$(Dev)Gain:2-RB") {
  field(DESC, "COMPENSATION FACTOR B IN")
record(ai, "$(Sys)$(Dev)Gain:8-RB") {
  field(DESC, "COMPENSATION FACTOR 3300pF D IN")
Kaz
Sent: Thursday, April 28, 2016 12:35 PM
To: Gofron, Kazimierz
Cc: Zhang Yuliang; [email protected]
Subject: Re: stream Device I/O error
What version of StreamDevice are you using?  I’ve got a crate monitor prototype file that assigns to a lot more than four records:
query {
    out "Q";
    in ":"
       "SN=%(\$1Serial.VAL)39[^,],"
       "UN=%(\$1Name.VAL)39[^,],"
       "IP=%*[^,],"
       "V3=%d,"
       "V5=%(\$1VP5.RVAL)d,"
       "V+12=%(\$1VP12.RVAL)d,"
       "V-12=%(\$1VM12.RVAL)d,"
#       "VAUX=%*[^,],"
       "T1=%(\$1Temp1.VAL)d,"
       "T2=%(\$1Temp2.VAL)d,"
       "T3=%(\$1Temp3.VAL)d,"
       "T4=%(\$1Temp4.VAL)d,"
       "F1=%(\$1Fan1.VAL)d,"
       "F2=%(\$1Fan2.VAL)d,"
       "F3=%(\$1Fan3.VAL)d,"
       "F4=%(\$1Fan4.VAL)d,"
       "F5=%(\$1Fan5.VAL)d,"
       "F6=%(\$1Fan6.VAL)d,"
       "F7=%(\$1Fan7.VAL)d,"
       "F8=%(\$1Fan8.VAL)d,"
       "F9=%(\$1Fan9.VAL)d,"
       "OT=%*[^,],"
       "OV=%*[^,],"
       "OC=%*[^,],"
       "PS1=%(\$1PS1status.VAL)d,"
       "PS2=%(\$1PS2status.VAL)d,"
       "MSG=%*[^,],"
       "SW=%(\$1PowerSwitch.VAL)d,"
       "PROT=%*[^,],"
       "I3=%*[^,],"
       "I5=%*[^,],"
       "I12=%*[^,],"
       "I-12=%*[^,],"
       "CODE=%(\$1Firmware.VAL)39[^,],"
       "ENET=%*[^,],"
       "POH=%(\$1HoursOn.VAL)g,"
       "MAXTMP=%(\$1MaxTemp.VAL)g,";
    ExtraInput = Ignore;
On Apr 28, 2016, at 9:20 AM, Gofron, Kazimierz <[email protected]<mailto:[email protected]>> wrote:
Hi Yuliang,
Redirection works only for up to 4 values read in (3 redirections). At least that is what I am seeing when increasing number of redirections.
Eric Norum
stream Device I/O error Gofron, Kazimierz
Re: stream Device I/O error Zhang Yuliang
Re: Re: stream Device I/O error Zhang Yuliang
RE: Re: stream Device I/O error Gofron, Kazimierz
Re: stream Device I/O error Eric Norum
Prev: Frame grabber for linux box Kevin Jordan
Next: RE: calc question Gofron, Kazimierz
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: stream Device I/O error Eric Norum
Next: Re: stream Device I/O error Dirk Zimoch
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
