1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Frame grabber for linux box
To: Brian Freeman <[email protected]>
Date: Fri, 29 Apr 2016 07:52:31 -0500
Kevin, Brian,
You might also consider feeding the signals from your analog cameras into an Axis video server, which is well under $1K for a 4 channel server. This allows you to grab JPEG images over http from any machine and with many software choices, such as wget.  You can use the ADURL driver to read these images into areaDetecor to use its features and plugins.
But also: the USB3/GigE cameras from Point Grey are very good and reliable.  The configuration software and example viewer they provide for setting up the cameras is also very good.  To limit the GigE cameras from swamping the rest of the network traffic, we tend to feed them into a second NIC on the machine running the areaDetector IOC.
--Matt Newville
Frame grabber for linux box Kevin Jordan
RE: Frame grabber for linux box Mark Rivers
Re: Frame grabber for linux box Brian Freeman
Prev: RE: Frame grabber for linux box Mark Rivers
Next: RE: Frame grabber for linux box tom.cobb
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024
Next: RE: Frame grabber for linux box Mark Rivers
ANJ, 15 Jul 2016 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
