1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Frame grabber for linux box
To: <[email protected]>
Date: Fri, 29 Apr 2016 21:02:43 -0700
Hi Kevin,
I'm working on an areaDetector driver for EDT digital camlink framegrabbers
which is nearly ready for community use.
EDT doesn't make an analog framegrabber though, so I don't know how
much help it would be.    If you decide to write your own AD driver for your
framegrabbers I could make the code available to you for comparison purposes.
Cheers,
- Bruce
On 04/28/2016 03:39 PM, Mark Rivers wrote:
Hi Kevin,
I don't know of any areaDetector support for analog frame grabbers.  Is there a hard requirement for analog cameras?  There are quite inexpensive GigE cameras now available with areaDetector support.  For example, the Point Grey Blackfly cameras are under $500 for 2048x1536 at 35 frames/s, and under $300 for 1280x960 at 52 frames/s.
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Kevin Jordan
Sent: Thursday, April 28, 2016 3:15 PM
To: EPICS Tech Talk
Cc: Brian Freeman
Subject: Frame grabber for linux box
Hi Folks,
We are setting up Area Detector for an electron gun test stand on a linux box. We intend to use both analog and digital cameras.
Please comment on which frame grabber we should purchase.
Thanks in advance,
Kevin
Kevin Jordan PE
Diagnostics Group Leader
Center for Advanced Studies of Accelerators
Jefferson Lab
12000 Jefferson Av
Newport News VA 23606
cell; +1-757-876-1742
Bruce Hill
Member Technical Staff
SLAC National Accelerator Lab
2575 Sand Hill Road M/S 10
Menlo Park, CA  94025
Frame grabber for linux box Kevin Jordan
RE: Frame grabber for linux box Mark Rivers
Prev: Lock/Mutex to prevent "caget" from cutting in between updating multiple fields Zhang, Dehong
Next: RE: Lock/Mutex to prevent "caget" from cutting in between updating multiple fields Mooney, Tim M.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Frame grabber for linux box Mark Rivers
Next: LinMot Motor Controllers bob dalesio
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
