1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Lock/Mutex to prevent "caget" from cutting in between updating multiple fields
To: "Zhang, Dehong" <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Sat, 30 Apr 2016 09:01:44 -0400
Pvaccess has atomic get/put from multiple records. This work was supported by RAON along with the first cut of pvaccess gateway and done by Matej Sekoranja and Michael Daividsaver. It requires the modified record locking. This does not work across IOCs. Michael should speak more directly to this.
On Apr 29, 2016 4:12 PM, "Zhang, Dehong" <[email protected]> wrote:
In my custom record, I need to update multiple fields atomically so they stay
synchronized -- all updated, or none updated; not a few updated, but a few with the
old data.  If I use my own mutex, I suspect that "caget" can cut in between the
updating and gets, for example, new data with old time stamp, or old data with
new time stamp depending on the order of updating.
And I guess "camonitor" would not have this problem because it would be the server
pushing the whole set (field itself and time stamp for instance).  Is this right?
So to close this hole with "caget", which global lock should I use?  dbScanLock?
Thank you, best regards,
Dehong
Lock/Mutex to prevent "caget" from cutting in between updating multiple fields Zhang, Dehong
Prev: Re: Lock/Mutex to prevent "caget" from cutting in between updating multiple fields Till Straumann
Next: Re: Lock/Mutex to prevent "caget" from cutting in between updating multiple fields Zhang, Dehong
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Lock/Mutex to prevent "caget" from cutting in between updating multiple fields Bruce Hill
Next: Re: EPICS 2016 Spring Meeting at ESS, Lund, Sweden Torsten Bögershausen
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
