1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Re: ca gateway problem
To: EPICS Tech-Talk <[email protected]>
Date: Wed, 4 May 2016 09:31:57 +0200
On 04/05/2016 07:01, Silver wrote:
Also I noticed if I use caput to write a value through ca gateway, like following:
geyang@cow1:~# caput inet:setai 5
Old : inet:setai 6
New : inet:setai 6
although the value was written correctly, but the display is not as common here. Anyone notice this?
Hi Geyang,
For write access through a GW to work, two layers of access security have to be configured correctly:
  1. The GW has to allow write access from the external client - this is done in the GW's access file.
  2. The IOC has to allow write access from the GW - this is done in the IOC's access security file.
The command line tool "cainfo" shows the current access rights for a client.
Can you run "cainfo inet:setai" on cow1? What access rights does it show?
Cheers,
~Ralph
ca gateway problem Silver
Re: Re: ca gateway problem Silver
Prev: Re: Reg programming in EPICS environment for master slave control Himanshu Tyagi
Next: Re: ca gateway problem Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Re: ca gateway problem Silver
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
