1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Example for User Created File Types in the build system
Date: Tue, 10 May 2016 21:22:11 +0000
I am looking for an example of how to use "User Created File Types" in the build system to add some custom files to the generated product. I've followed the documentation in the App Developer guide (R3.14.12.4) and created a CONFIG_ABC in my app's src folder.
$ cat userFileTypeApp/src/CONFIG_ABC
FILE_TYPE += ABC
INSTALL_ABC = $(INSTALL_LOCATION)/abc
I then include this in the app's Makefile;
CFG += CONFIG_ABC
and add a sample file like so.
ABC += test.abc
1) When I run make for the first time, only the cfg folder shows up. I expected the "abc" folder to show up but it didn't.
2) If I run make again, the abc folder does indeed show up and it does have the "test.abc".
3) And when I run "make clean distclean", the abc folder stays behind.
Would anyone have a example that I could use as a reference?
Murali
Re: Example for User Created File Types in the build system Andrew Johnson
Re: Example for User Created File Types in the build system Shankar, Murali
Prev: RE: EPICS support with NI-Daqmx freddie.akeroyd
Next: Re: Example for User Created File Types in the build system Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: ORNL Job Posting: Accelerator Physics Application Programmer Cherry, Steve J.
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
