I am writing EPICS driver for Keithley 3706A, and am trying to figure out how to send long string commands to the 3706A.
The ICL commands have no short version, and some commands exceed current 40 char length limit of the stringout record.
____
The EPICS stringoutRecord.h is limited to 40 char.
char val[40]; /* Current Value */
In my driver assigning to stringout:
"dmm.setconfig('1019:1020','fourwireohms')"
results in "dmm.setconfig('1019:1020','fourwireohms" being send - missing last 2 characters
Is there a replacement for stringout with relaxed limit?
Simplified command/respond test:
record(stringout, "$(P)$(Dmm)command") {
field(FLNK, "$(P)$(Dmm)reply")
record(stringin, "$(P)$(Dmm)reply") {
field(DTYP, "asynOctetWriteRead")
field(INP, "@asyn($(PORT) 0) $(P)$(Dmm)command")
I am currently using this format in the driver:
record(stringout, "$(P)$(Dmm)dmm_read") {
field(DTYP, "asyn so stringParm")
field(FLNK, "$(P)$(Dmm)dmm_get_str.VAL PP MS")
field(VAL, "print(dmm.measure())")
field(OUT, "@asyn($(PORT))TERM=0a")
record(stringin, "$(P)$(Dmm)dmm_get_str") {
field(DTYP, "asyn si stringParm")
field(INP, "@asyn($(PORT))TERM=0a,TO=10000")
field(FLNK, "$(P)$(Dmm)read_finished.VAL PP MS")
Kazimierz
- RE: long string command to device Mark Rivers
- AW: long string command to device Zimoch Dirk (PSI)
Re: Recommendation on a PCIe ADC board Ford, Christopher
<2016>
RE: Model 8743 Closed-Loop Picomotor,Controller / Driver Mark Rivers
<2016>
