1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: generalTime time provider consternation
Cc: [email protected]
Date: Fri, 13 May 2016 09:17:13 -0300
Thanks.
I think returning epicsTimeERROR is the right thing to do if the time card is not synchronized to its reference .  I don't know why I hadn't considered that before....
On Thu, May 12, 2016 at 6:16 PM, Andrew Johnson <[email protected]> wrote:
Hi Mike,
On 05/12/2016 02:21 PM, Michael Westfall wrote:
> Our problem comes when the Bancomm board is not locked to it's reference
> signal and happens to have a time set that is in the past compared to
> NTP time.
> EPICS timekeeping becomes erratic and eventually grinds to a halt, and
> records set to scan at periodic rates quit processing.
Is your driver able to tell when it is not locked?
I think the idea is that a time provider must only return OK if it knows
it has a good source of time. I think you need to modify your provider
to return an error when it isn't locked, because only then will the
generalTime code try the next provider in its list.
The code that scans the provider chain is dumb; it will only move on to
the next provider when the first one returns an error (and so on), and
it doesn't remember the state from the last time it scanned the chain,
it always starts again from the top for every request. Thus if a higher
priority provider always returns OK but gives a time in the past, the
current time will not step backwards because of the built-in ratchet
mechanism, but it won't step forwards either until the provider tells it
to, so the periodic scans will hang just as you're seeing.
> Why does time keeping become erratic when  "backwards time" is prevented?
Some code makes use of the OS to time events, but others such as the
periodic scans look at the absolute time.
It has been suggested that the generalTime code needs rewriting again.
Time is a notoriously hard thing to handle properly; some APIs want
absolute times while others want relative times, and keeping the two
synchronized is a problem.
HTH,
- Andrew
Mike Westfall
Control Systems Software Engineer
generalTime time provider consternation Michael Westfall
Re: generalTime time provider consternation Andrew Johnson
Prev: AW: long string command to device Zimoch Dirk (PSI)
Next: Re: Question about Archive Engine Kasemir, Kay
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: generalTime time provider consternation Andrew Johnson
Next: Model 8743 Closed-Loop Picomotor,Controller / Driver D Peter Siddons
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
