1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: error when make base3.15.3
To: Benjamin Franksen <[email protected]>
Cc: 梁雅翔 <[email protected]>, tech-talk <[email protected]>
Date: Thu, 19 May 2016 09:05:31 -0300
 Translation says unterminated #if 0
2016-05-19 8:51 GMT-03:00 Benjamin Franksen
<[email protected]>:
> Correction: I think it should be LANG=C:
>   > make distclean
>   > LANG=C make
> Am 19.05.2016 um 13:43 schrieb Benjamin Franksen:
>> Hi Liang
>> It would help if you could prefix the  build command ("make") with
>> "LANGUAGE=C" (and then re-send the output), so we can see the error
>> messages in English.
>> Cheers
>> Ben
>> Am 17.05.2016 um 14:54 schrieb 梁雅翔:
>>> Hi everyone,
>>>    I have some error when I make base3.15.3 in Fedora 23.
>>>    I set the environment of EPICS_HOST_ARCH=linux-x86_64 and EPICS_BASE=/opt/epics/base, EPICS_EXTENSIONS=/opt/epics/extensions
>>>    Can you tell me the reason?
>>> This is my information.
>>> make[2]: Leaving directory '/opt/epics/base/src/libCom/RTEMS'
>>> make -C libCom/test install
>>> make[2]: Entering directory '/opt/epics/base/src/libCom/test'
>>> make -C O.linux-x86_64 -f ../Makefile TOP=../../../.. \
>>>     T_A=linux-x86_64 install
>>> make[3]: Entering directory '/opt/epics/base/src/libCom/test/O.linux-x86_64'
>>> make[3]: Nothing to be done for 'install'.
>>> make[3]: Leaving directory '/opt/epics/base/src/libCom/test/O.linux-x86_64'
>>> make[2]: Leaving directory '/opt/epics/base/src/libCom/test'
>>> make -C ca/client install
>>> make[2]: Entering directory '/opt/epics/base/src/ca/client'
>>> make[3]: Entering directory '/opt/epics/base/src/ca/client/O.linux-x86_64'
>>> /usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../src/ca/client/test -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF searchTimer.d  ../searchTimer.cpp
>>> ../searchTimer.cpp:151:0: Error:未终止的 #if
>>>  #if 0
>>> /usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../src/ca/client/test -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../searchTimer.cpp
>>>  #if 0
>>> ../searchTimer.cpp: 在成员函数‘virtual epicsTimerNotify::expireStatus searchTimer::expire(const epicsTime&)’中:
>>> ../searchTimer.cpp:150:33: Error:expected ‘}’ at end of input
>>>      if ( this->searchAttempts ) {
>>> ../searchTimer.cpp:150:33: Warning:在有返回值的函数中未发现 return 语句 [-Wreturn-type]
>>> ../../../../configure/RULES_BUILD:228: recipe for target 'searchTimer.o' failed
>>> make[3]: *** [searchTimer.o] Error 1
>>> make[3]: Leaving directory '/opt/epics/base/src/ca/client/O.linux-x86_64'
>>> ../../../configure/RULES_ARCHS:61: recipe for target 'install.linux-x86_64' failed
>>> make[2]: *** [install.linux-x86_64] Error 2
>>> make[2]: Leaving directory '/opt/epics/base/src/ca/client'
>>> ../configure/RULES_DIRS:88: recipe for target 'ca/client.install' failed
>>> make[1]: *** [ca/client.install] Error 2
>>> make[1]: Leaving directory '/opt/epics/base/src'
>>> configure/RULES_DIRS:88: recipe for target 'src.install' failed
>>> make: *** [src.install] Error 2
>>> Thanks,
>>> Liang
> "Make it so they have to reboot after every typo." ― Scott Adams
error when make base3.15.3 梁雅翔
Re: error when make base3.15.3 Benjamin Franksen
Prev: Re: error when make base3.15.3 Benjamin Franksen
Next: EPICS meeting : HW platform support discussion group Jeong Han Lee
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: NTP time provider and ticksPerSecond Michael Westfall
ANJ, 15 Jul 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
